Question about Garmin StreetPilot c510 Deluxe GPS Receiver
Powers up but then stops with a message
Message reads
NO DETAILED MAPS FOUND THAT SUPPORT ROUTING.THE STREET PILOT CANNOT BE USED WITHOUT THEM.
then it just sits there.
also now it wont connect the my pc.
this happened after i updated maps
please help
i have tried the reset behind the front panel to no avail
  • 5 more comments
  • Anonymous Jan 25, 2008
    no detailed maps found that support routing. the street pilot cannot be used without them.
    andy c. no detailed maps found that support routing.the streetpilot cannot be used without them. pressed the reset button plenty of times still wont work. cannot even get on to the main screen. the msge is just frozen on the screen
  • Anonymous Feb 24, 2008
    Same message appear on screen no detailed maps found that support routing. I need help.
  • Anonymous Jun 02, 2008
    after updating the maps
  • mustmax Aug 14, 2008
    SAME PROBLEM HERE TOO !!!
  • garmin2008 Aug 24, 2008
    Tried master reset
  • wozza12345 Sep 03, 2008
    message reads
  • 174 Answers
Turn on the Garmin and look for the little wrench. Press the wrench and now find Map. Press Map and look for Mapinfo. Press Mapinfo and verify that there is a check mark next to the Mapsource Map.
If you press Mapinfo and there is nothing, then your Mapsource upgrade did not go through.
Posted on Jan 11, 2008
I solved problem by sending the unit back to garmin europe who fixed it under warranty. they did suggest a master re set which can be done by pressing the bottom right hand corner of the screen hard then turning the unit on at the same time. it wil then say re set all data? hit yes. if this does not work, send it back!!!
Posted on Mar 17, 2008
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Just updated the software with webupdate for windows_242 from garmin website succesfully. ''No detailed maps found that support routing. The street pilot cannot be used without them. comes up when...
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  3. Select Details
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
To check that the map has not been disabled. Press Tools, then press Settings, then press Map, then press Map Info and see if your map has a tick to show it's selected. If not press the map name to select it. It should then work.
Jul 27, 2010 | Garmin GPS
Keep getting
It means that your unlock file for you map has either been corrupted or deleted. The file needs to be restored. Please see this link for more information:
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Aug 11, 2009 | Garmin nuvi 205W GPS Receiver
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
May 10, 2009 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Garmin StreetPilot  c510 Deluxe GPS Receiver Logo
505 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
