Question about Toshiba Satellite A105 Notebook
I have toshiba a100 .. its not turning on.. when i put the charger on and power on botton its flash bettery light 5 times .. but not turning on .... plz help me to solve this prob...
  • mundodospcs Dec 04, 2009
    no .. its not turning on .. not direct non with the battery.. only flash battery light nothing else shows..
  • sandip panchal
    sandip panchal May 11, 2010
    when u plug your charger then your laptop will be (run) properly on or not
Not working
Posted on Nov 30, 2009
Error code orange light flashes toshiba a10
This indicates a motherboard issue, I would suggest a professional at this point to access if it can be fixed at a realistic cost.
Mar 08, 2012 | Computers & Internet
Problem: A100 flashing Amber light but won't turn
Check your charger. It seems to indicate low batery and the charger may not work or the power socket has a faulty connection. Check for phisical damage in the power socket of you laptop.
Try to twist it or even push it in a bit while trying to switch on. Try also to remove the baterry and use the charger power supply only.
If nothing happens its very likely to be the charger.
Jul 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
Can not swich on even if the battery is ok
Remove both the AC cord and the battery for 1 minute. Then plug in AC only and see if PC will power up. If not, next connect both AC and Battery.
Be sure to press and HOLD power button for >5 seconds when powering a Laptop.
Feb 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba-A100 problems
Remove the battery and try to run your notebook on the adapter itself.....does it work....does the light do the same
Reinstall the battery...please verify that its locked in place..there is a small lock catcher verify that its at the lock position....connect power adaptor switch on...
post your results
if this fixed your issue please do not forget to vote!
Cheers!
Nov 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Charger
Looking for a new one? Would you like me to find one for you? Just say the word and I'll be happy to do that for you.
Apr 18, 2008 | Computers & Internet
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Toshiba Satillite A100 not powering up
hi
again $ again try 3 or 4 time to powerin on with ac mode,if not powering on then try it in backup mode with support battery if u dont have battery backup then get a battrey from any other laptop but it must be same model if powering on then change your adapter and try again if then also not warking go to nearer vender or service center.
by by.
Nov 18, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105 Notebook Logo
251 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
