Question about Acer Aspire 3000 Notebook
When turning my p.c on my screen sais"no input signal" and my tower starts making a bleeping noise please help
    President:
  • 2,030 Answers
Sounds like you have something stopping your tower from booting.
Have your power supply checked out, then if thats not it you may have a bad motherboard or CPU.
Posted on Nov 13, 2009
Pc boots up, but shows no signal on monitor. then pc will no shut off
check all leads to your hard drives and make sure they are a tight fit.if its bleeping on start up then check all leads.
check your vga lead from your tower to your screen.
Mar 27, 2015 | Computers & Internet
The screen remains black, laptop won't boot, fan makes a low noise
try test an external screen to the computer, if you got it working, you have a broken backlight
Dec 29, 2013 | Computers & Internet
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
When i turn on my p.c my screen sais"no input signal"and my tower is making a bleeping noise please help
beeps and no signal are indicators of either a failed or unseated graphics card or memory you will need to remove case to check components fixtures.get rid of beeps and it should boot ok
Nov 13, 2009 | Computers & Internet
Every time i turn on my ps3 it sais no signal help?
need to get a new av wire beacuse wire is broke or u did the wiring wrong
Aug 12, 2009 | Video Game Consoles & Games
Hp w1907 monitor not detecting vgi input from original HP x3122 computer
It sounds like your computer has been having some trouble for some time. My hunch is that there is nothing wrong with the monitor at all.
Usually, when you see this warning on the screen that there is no signal, the monitor is trying to tell you that it cannot talk to the computer. This means the computer either a.) will not boot or b.) your video card in the computer has stopped working.
Does your computer make all the usual noises when you start it up? Can you hear the hard drive clicking and the fans come on?
Have you reseated the video connection on the back of the tower?
My guess is that something was going out before and it is now gone. The first place I would look to diagnose this problem is the hard drive.
Hard drives fade to fail sometimes, and when they are fading, the entire computer becomes painfully slow.
Hope this helps
good luck
tony
May 19, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Nothing comes up on the screen
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
When switching on PB not loading and is realising loud bleep
yes the beep pattern. btw , try checking your memory if you have 2 of them on try removing the other 1 then turn on pc. n do it vice versa. if
Jan 22, 2009 | Acer Aspire™ T180 PC Desktop
Alarm
Beeps usually indicate something is not plugged in or a program is not running properly for 'whatever' reason...r there any errors on your screen? If not, does it continue to beep after window icons have loaded? If so, try typing ctrl/alt/delete (at same time) to see if an apllication continues to run b4 it shuts down... If so, note that program application file, as you may need to delete that program and reload it to solve your 'beep'. Had a similar problem with my Canon fax/scanner/printer...Hope this helps.....DayGirl48
Jan 26, 2008 | Packard Bell iWork 9427 (P721001702) PC...
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
