Question about Hand Tools
Bulb replacement for a Sears Craftsman Driver
Need to locate a bulb to install in a Sears Craftsman Driver Light Screw Driver Model 41993. There is no bulk in the existing battery/lamp assembly.
  • 4 Answers
SOURCE: sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Posted on Apr 19, 2008
  • 5 Answers
SOURCE: Sears Craftsman Sprocket replacement procedure
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Posted on Jul 10, 2008
  • 3 Answers
SOURCE: Parking lamp bulb replacement.
hey,
you have to use a pretty long screw drive to gently push down on the release tab, slowly wiggle the lens assembly until it move forward a little... depending on how long its been since the last time it was changed, you might have to be a little more aggressive in your wiggling to get it to slid forward.
I just change my front turn signals from yellow to Euro white, looks freaking sweet as hell.
Well, I hope I helped... it would be a shame for you to waste money at the dealership for something like that.
Drive to Seattle and replace it for you... Lol
Good luck
325iDegrees
Posted on Jul 11, 2008
SOURCE: SOLUTION: HOW TO REPLACE REAR BULBS ON 2002 & 2004 BUICK LESABRE
Rear tail lamps for the 2002 La Sabre has eight nuts that hold the cover in place ( one piece-all acroos the back of the car). Do not remove the nuts for the lock, the cover sits in place and is not secured to the lock. Use a 10 mm deep well socket. remove the nuts and lift the cover to replace the burned out bulb(s). The bulbs are #194 or #198 (very small bulbs), not the 3057. It is easy to locate the burned out bulbs by putting the car in reverse and shutting off the engine and then put the ignition key in the accessory mode. The lights will light unless they are burned out. Simply pull them out and replace with the new ones and put the cover back in place and secure the nuts.
Posted on Feb 23, 2009
frankzen
  • 19 Answers
SOURCE: Hi. I need a Sears Craftsman 16 volt battery
www.craftsmancordless.info
Posted on Apr 04, 2009
How do I open the Nitelighter NL55 pool light to replace the bulb?
There is a screw that holds the surround in place and holds the lamp assembly. U have to then open up the lamp assembly to install the new bulb and reseal all so no water gets in. Then put back and while under water get the surround in along with the screw. A real PIA and very hard to do when buoyancy keeps pushing you up when you want to stay down there to do the job while holding your breath and screw driver, surround and screw.
Aug 23, 2017 | Pool & Spa
How to replace brake light bulb audi a4 1.8t 2002
Start by opening the trunk lid. On the sides of the trunk, just beside where the trunk lid sits when closed there is a circle cap on either side. Remove the cap it is the same material as the trunk side trim (fuzzy carpet) then there will be a screw set into the hole that you just uncovered. You can use either a philips screw driver or an 8mm socket and remove the screw/bolt. you may need to reach in with a set of needle nose pliers to remove the screw after it is loosened all the way. Once the screw is removed grab the tail lamp assembly from the inside and twist the tail lamp out of the holding pins located on the side edge of the tail lamp. The whole light will come off of the body in your hands. Once the tail lamp assembly is out there is an access panel on the back side where all the bulbs are installed. Depress the two holding tabs on the sides and carefully remove the bulb holder. Then replace any blown bulbs and reinstall.
Jan 17, 2014 | 2006 Chrysler PT Cruiser
How can I take off the tail light assembly to replace the bulb for the left tu
Open the trunk. In the left corner where the lamp assembly is, you should see two screw covers that cover the screws holding in the lamp assembly.
Remove these covers to find the screws, and unscrew them to pull the taillamp assembly out of the vehicle body. Disconnect the lamp wiring harness, turn the bulb socket counterclockwise to pull out the socket, revealing the light bulb. Then pull the bulb right out of the socket and replace it with a new bulb.
Replace the socket, turning it clockwise. Replace the taillight assembly. Check that the taillamp assembly tab, located at the bottom of the taillamp assembly, is aligned to the facia bracket before securing the screws.
Screw the taillamp assembly back into the vehicle body and replace the screw covers. Check to make sure the new bulb works properly.
Your owners manual specifies that the rear left turn lamp is a lamp with bulb number 3057K. You should be able to find them at any automotive store or from your dealer. Hope this helps.
Dec 05, 2012 | 2011 GMC Terrain
Is there a trick to getting to the rear turn signal on a 2003 ford focus hatchback. I had removed the screw to the lens cover but I still cannot gain access to the turn signal bulb to replace it.
Replacing tail/brake/backup lights and turn signal bulbs (coupe)
1. Make sure the headlamp control
is in the OFF position and then
open the hatchback.
2. From inside the luggage
compartment remove the wing nut
of the rear light assembly cover.
3. Using a Phillips screw driver
remove the screw. The lamp is still
retained by a spring loaded clip.
Remove by gently pulling out the
light housing.
4. Turn the bulb socket counterclockwise as far as possible and pull it
out.
5. Pull the bulb straight out of the socket.
Install in reverse order.
Replacing tail/brake/backup lights and turn signal bulbs (sedan)
open the trunk.
compartment remove the three wing
nuts of the light housing.
3. Gently pull the light housing to
the outside.
counterclockwise and pull it out.
Replacing tail/brake/backup lights and turn signal bulbs (wagon)
open the hatchback.
2. Using a screw driver remove the
fixings and trim from the body.
3. Remove the socket from the lamp
assembly
4. Pull the bulb straight out of the
socket.
Hope this helps.
Zeppelinx12
Mar 03, 2011 | 2003 Ford Focus
Replace a brake light
COUPE The side marker lights for the SC and SC2 are part of the turn signal/parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. Rear Turn Signal, Brake and Parking Lights EXCEPT WAGON
  1. Disconnect the negative battery cable. Fig. 5: Remove the trim panel fasteners - except wagon 84196109.jpg
    Fig. 6: Carefully remove the trim panel - except wagon 84196110.jpg
    Fig. 7: Pull the lamp assembly straight back and out of the opening 84196111.jpg
  2. Remove the trim panel fasteners, then carefully remove the trim panel.
  3. Remove the 2 retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  4. Tilt the assembly downward for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  5. Installation is the reverse of removal. Fig. 8: Tilt the assembly downward for access to the sockets 84196112.jpg
    Fig. 9: Twist and remove the socket and bulb from the lamp assembly 84196113.jpg
WAGON
  2. Remove the retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  3. Tilt the assembly for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  4. Installation is the reverse of removal. Fig. 10: Exploded view of the tail lamp assembly - wagon 84196114.gif
High-Mount Brake Light EXCEPT WAGON
  2. Open the trunk for access to the lamps.
  3. Locate the bulbs at the rear underside of the trunk lid. Remove the bulb(s) by twisting, then pulling straight out.
  4. Installation is the reverse of the removal. Fig. 11: Remove the high-mount brake light by twisting its socket 1?4 turn counterclockwise - except wagon 84196115.jpg
WAGON
  2. Raise the liftgate, then remove the wedge blocks from each side of the liftgate assembly.
  3. Remove the lower fasteners from the liftgate lower trim panel, by pushing in the center of each pin approximately 1?8 in. until it clicks, then remove the fastener.
  4. Insert a screwdriver or small prybar into the hole in the lower trim panel (located near the wiper pivot on the pivot hump) so that the tool sits on top of the pivot. Lift up on the tool handle to disengage the trim panel upper clips, then remove the lower trim panel from the vehicle.
  5. Unplug the high-mount brake light wiring harness.
  6. Remove the brake light fasteners, then remove the lamp assembly from the liftgate.
  7. To remove the bulb(s), push slightly on the top edge of the lens and rotate it away from the housing. Remove the bulb(s) from the housing. To install:
  8. In order to prevent the possibility of water leaks into the liftgate, inspect the lamp gasket for damage and replace, if necessary.
  9. If removed, install the bulb(s) by inserting the bottom edge of the lens into the housing and snapping it into place.
  10. Position the lamp into the liftgate and tighten the fasteners to 35 inch lbs. (4 Nm).
  11. Connect the wiring harness to the lamp assembly.
  12. Align the upper clips on the lower trim panel to the liftgate slots, then install the panel by pushing at the clip locations.
  13. Reset the trim panel push-in fasteners by spreading the center pin tabs and moving the pin so that it sits approximately 1?4 in. out of the fastener. Insert the fasteners into the bottom of the trim panel and push the center pin until flush.
  14. Install the liftgate wedge blocks.
  15. Connect the negative battery cable and check for proper lamp operation. Fig. 12: Removing the liftgate lower trim panel assembly - wagon 84196116.gif
    Fig. 13: Exploded view of the high-mount brake light bulb and lens assembly - wagon 84196117.gif
Nov 04, 2010 | 1998 Saturn SL
I need to replace rear tail light bulbs on 1996 Saturn SL1
WAGON
WAGON
Reverse Light EXCEPT 1991-96 COUPE For the Saturn wagons and sedans, the reverse lamp is part of the rear turn signal, brake and parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. 1991-96 COUPE
  2. Reach behind the bumper bar and disconnect the harness and socket from the reverse lamp. Remove the bulb from the socket.
  3. If necessary, unfasten the retaining nuts and remove the lamp from the bumper bar.
  4. Installation is the reverse of the removal. Fig. 14: Exploded view of the reverse lamp mounting - 1991-96 coupe 84196118.gif
Oct 23, 2010 | 1996 Saturn SL
2008 kia optima break lights not working
  • kia optima brake light
  • Open the hood and locate the battery. Remove the cable from the negative terminal (black cable) by turning the retaining nut on the cable clamp counterclockwise with a socket wrench until the clamp is loose enough to slide off the terminal. You must disconnect the battery's negative terminal to avoid a potential electrical shock when working on any electrical component in your KIA.
  • Open the trunk and pull back the carpet near the tail light assembly.
  • Remove the three nuts holding the lamp assembly in place and pull the lamp assembly out.
  • Remove the bulb assembly by rotating the bulb counterclockwise and pulling the bulb straight out of the housing.
  • Install the new bulb. Installation is the reverse of removal.
  • Reconnect the cable to the negative battery terminal.
  • Aug 11, 2010 | 2008 Kia Optima
    How do you change the headlight bulb on 1996 olds delta 88? I cannot get to the bulb assembly.
    REMOVAL & INSTALLATION
    See Figures 1, 2, 3 and 4
    2. Remove the fog lamp-to-bumper assembly retaining screws. Be careful not to disturb the adjusting screw.
    0900c152800b1fa2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Unfasten the 2 Torx® fog light retaining screws (1), making sure not to disturb the adjusting screw (2)
    1. Squeeze the bulb and socket assembly retaining clip prongs inward, and pull the bulb and socket from the rear of the fog lamp.
    0900c152800b1fa3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Squeeze the bulb and socket retaining clip prongs inward ...
    0900c152800b1fa4.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: ... then pull the bulb from the rear of the fog lamp
    1. Unplug the fog lamp electrical connector.
    0900c152800b1fa5.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 4: Unfasten the fog lamp electrical connector
    1. Install the assembly, retaining bolts and connect the negative battery cable.
    AIMING
    1. Park the car on a level surface, at least 25 ft. (7.6m) from a wall that is perpendicular to the ground surface. Make sure there is no excess weight in the trunk, unless you normally travel with that amount of weight in the car. Bounce the car a few times to settle the suspension.
    2. Measure and record the distance from the ground to the center of each fog light lens.
    3. Turn the fog lights on and adjust so the hot-spots (lit area of most concentrated intensity) are 4 in. (10cm) below the height of the lenses. The ADJUSTING screw is located at the top right corner of the fog light.
    Jan 25, 2010 | 1996 Oldsmobile 88
    I have a craftsman driver light #41993. Its
    I know this is an old post but noticed there are 385 people that have viewed the post that like me were searching for a fix to their Craftsman 41993 lighted driver. The fix I found resulted in a better light than the original but being a Craftsman purist I also found a way to fix the original as well even though I put it away and use the new fix. I just wanted the original to work again. I'll start with repairing the original. The usual problem with the original is caused by corrosion from leaky batteries that ends up corroding through the metal strip connecting the + and - ends. I tore apart a new freebie led flashlight from Harbor Freight and used the guts to replace the metal strip and spring that was corroded beyond repair on my light. All it took was a little bending and snipping to make it identical to what my Craftsman had. You will notice the guts of the HF light have a nearly identical metal strip with spring attached. I cleaned the 41993 parts thoroughly & reassembled it using the remaining parts and the new metal strip and spring that I fabricated from the Harbor Freight light. It worked like a charm and my light works like it did when it was new. Now for the best part because my upgrade takes this light to a whole new level. Remove the old light and store it in a safe place. Then get another 3 1/2" Mini Flashlight from Harbor Freight item #69052 for free if you have a coupon since this item is often the freebie given away with any other purchase. I have a half dozen lying around myself so I know this to be fact. Remove the small lanyard and circular clip from the light and toss it since you will no longer need it. Pick up one super thin O-ring from a hardware store that will fit over the end of the flashlight and place it over the end of the light with the push button until it rests in the first groove. I can't give you a size since I sifted through several until I found one that fit snug with a little stretching to get it over the end of the light. Then slide the light into the 41993 and work the o-ring into handle with a small jewelers screwdriver as you gently press the light in place. This doesn't take too much pressure unless you chose a thicker o-ring. You don't absolutely have to use an o-ring but I like the professional appearance of the o-ring and the fact that it serves as a moisture barrier. The new replacement light fits so well that it looks like it was made for the 41993. The plus is that it has 9 LED's and illuminates the 41993 like the sun. Trust me that you will never again use the original once you install the new upgrade. Hope this helps another Craftsman tool junkie like me.
    Dec 16, 2009 | Hammer Hand Tools
    How to change 4 runner front blinker light. there's a phillips screw under the hood I have removed but there is another fastener in the lower portion of the blinker housing I cannot locate.
    Remove or disconnect the following:
    • Connector
    • Screw
    • Claw fitting
    • Front turn signal lamp assembly
    • Front turn signal lamp plug assembly
    • Front turn signal lamp bulb as shown
    To Install:
    1. Install or connect the following:
      • Front turn signal lamp assembly with screw
      • Connector
    Oct 01, 2009 | 2004 Toyota 4Runner
    Hand Tools Logo
    251 people viewed this question
    Top Hand Tools Experts
    Don Numinen
    Don Numinen
    Ivan
    Ivan
    Level 1 Expert
    Bill Boyd
    Are you a Hand Tool Expert? Answer questions, earn points and help others
