Question about Kitchen Ranges
Oven door locked
I cleaned my oven yesterday and tried to open the lever before it was ready and now my oven door seems to be locked (no matter which position you put the lever)
  • 234 Answers
THIS IS NOT A STRANGE PROBLEM. Many times the lever that you move to lock door becomes slightly bent and it now will not travel completely to the unlock position (yet you can't tell just by looking) and it only needs to travel another 1/8 or 1/4 inch; you need to bend the handle in the oposite direction in order to get the extra clearance when moved to the unlock position. If this does not work, then you need to remove the burner top; some lift up, others need the individual burners removed (unscrewed) so the burner top can be lifted. Inside you will see a metal arm attached to the lever. This arm is either moved by a small servo-motor (geared rotation motor) or it is attached to a small micro switch or magnetic selenoid. You may need to disconnect the arm or rod from any of these components in order to move the lock lever and tereby release the lever tong from the door. Goodluck, Macgivor
Posted on Nov 13, 2009
Testimonial: "Your solution worked!! I am so grateful!"
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    After cleaning my GE XL-44 self cleaning oven, the door lock wouldn't unlock when I moved the lock lever back to the left. i moved it back to the lock position and tried again, and the lever broke off in...
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    May 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
    If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
    Mar 13, 2010 | Frigidaire 27 in. Electric Double...
    The oven door will not open after cleaning, and the oven cleaning has been done for over 1 hour? How can I get the door open?
    or
    If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
    Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
    Sep 16, 2009 | Kitchen Ranges
    After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
    This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
    Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
    Jun 03, 2009 | Ovens
    Jenn Air oven door won't open after clean cycle
    You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
    Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
    DOOR SHOWS OPEN BUT IT IS NOT
    After self cleaning the range the door won't open....
    The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
    Hope this may help;
    DON'T FORGET TO HELP
    Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
    Oven Door is locked and will not open
    On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
    Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
    GE Profile XL44 Spectra gas oven
    try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
    Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
    Kitchen Ranges Logo
    75 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
