Question about Marantz SR-5200 Receiver
Playstation 3 Plugged in playstation 3 with HDMI to a projector, the projector is connected to marantz but I cannot get any sound. Any suggestions?
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Posted on Feb 20, 2008
Green screen
Try to reset to your Marantz to factory settings, or try the newest Firmware. :)
Jan 21, 2014 | Marantz Audio Players & Recorders
It recognizes that there is an HDMI plugged in but when the television is set to the HDMI plug that is correct I have no picture and/or sound
Once the ps3 is set to use the av output it turns the hdmi output off so you need to go into the display settings menu select the connection/resolution and then scroll up to the hdmi output then press right to enable it.
Hopefully the tv should then find the hdmi connection.
You could also try as has already been suggested turning the ps3 off then holding the power button down on restart until it beeps, approx 5-10secs. This should reset the output. I would recommend unplugging the av output so the ps3 is forced to use the hdmi cable, make sure this is plugged in to both the tv and the ps3 first.
http://www.cable360.net/ct/operations/bestpractices/23213.html
Feb 27, 2010 | Sony Playstation 3 (PS3) Console
I am currently trying to hook up my playstation to my t.v. in the hotel & I have tried component cable, as well as an HDMI cable & the t.v. shows the cable is plugged in on the icon screen but...
connect the HDMI cable to the TV, then hold the "on/off" button on the ps3 for a few seconds, this causes the output settings to reset and the video/sound should work.
Dec 13, 2009 | Sony Video Game Consoles & Games
PLAYSTATION3 HDMI TO PROJECTION THEATER SYSTEM AND SOUND SYSTEM
HDMI from PS3 to projector, then output audio from profector to stereo.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Can't watch dvds on playstation 3
No, but you do have to select HDMI output in the settings in the PS3 menu and make sure the TV is switched to the correct HDMI input ( Whatever one you plugged your PS3 into)
Mar 13, 2009 | Sony PlayStation® 3 (80GB) Console
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Marantz vp4001 is completely dead??
warning indicator led lit up means something dis connectivity inside the projector
1)lamp cover switch or its connection from main board
2)fan connectors
3)thermistor connector
above casues for machine shows warnnig temprature indicater
and projector remains in standby mode
Jan 05, 2009 | Marantz VP4001 DLP Projector
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
Marantz SR-5200 Receiver Logo
357 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
