Question about Hammering
Hot water not working on my bathtub upstairs. How can I fix it?
  • 119 Answers
2 handle? 1 handle?
Posted on Nov 15, 2009
How would water get from upstairs bath to main floor if not the plumbing
Possibly high humidity is causing a buildup of condensation on the jot water line. One possible answer out of many. Need more info.
May 17, 2014 | Home
Shower is hot- bathtub is not- tempra tankless hot water heater
1) Test for crossover:
http://waterheatertimer.org/Crossover.html
2) Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 29, 2012 | Stiebel Eltron TEMPRA 24 Tankless Water...
I have a Delta scald guard shower faucet (older model). The cold water pressure is good but as a turn to hot the pressure drops to a drizzle. There are 2 other sinks and another shower upstairs and there...
It is more that likely the valve in the stem of your fixture, I'm assuming this is a single handle faucet. If you can replace the valve, you will cure your problem. I am giving you a link to how to adjust the hot water temp.
http://www.ehow.com/how_6531012_adjust-anti_scald-setting-delta-faucets.html
May 10, 2011 | Delta Home
Bathtub faucet only runs hot water. think it is hardwater problem because this faucet is closest to the waterheater. Other bathtub faucets in the house do not have this problem. Part of my water source...
there should be alternate little faucet knobs somewhere close one hot one cold, maybe you just have the hot knob turned to the maximum
Aug 29, 2010 | Moen Home
I have A whirlpool hot water heater I can get hot water downstairs but not upstairs through the shower and tub
Upstairs do you get hot water to your sink faucet. If you do this indicates to me that the temperature valve in your Shower & Tub may need to be adjusted.
For single handle please remove handle to gain access to dial that adjusts hot & cold water mixing.
Remember where it is and take it out and replace about a 1/8 to 1/4 turn counter clockwise and reinstall and try.
It is a plastic adjustment dial that will slide off after the handle is removed.
Trace lines if possible to assure correct pipe's are connected to valve.
May 20, 2010 | Home
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
My upstairs tub leaked and can see large water stains on the first floor ceiling. I think it only leaks if the jets are turned on. how do you fix this?
you will want to fill the tub up and turn the tub on first and get behind the tub and see where the water is coming from. there isn't any other way to find the leak.
Oct 15, 2009 | American Standard Home
Bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Feb 27, 2009 | Plumbing
Hammering Logo
492 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
