Question about Goodman GMS90703BXA Heater
It's not lighting it's not working I see motor is running and I think gas coming out but it's not lighting I turn off the funance
    Scholar:
  • 91 Answers
Turn the power off to the furnace, turn the thermostat to the highest heat setting then turn the power on. The fan may start for a brief period, then the combustion blower will start, after approx 90 seconds, the ignitor will light and heat up. You should be able to see a glowing in the burner lens. If you do not see a red glowing, similiar to a car lighter, that would indicate the ignitor may have failed. If after 3 attempts, the systems fails to light, there is a light on the circuit board that will flash, the number of flashes will indicate the reason for the fault.
Posted on Nov 13, 2009
Motors stsrts but will not contunal to stay running
I would think so, if the security light is on the computer is not registering the key, try turning the ignition to the "on" position for 15 minutes and see of the security light goes out and then see if it will start.
Aug 03, 2014 | 1999 GMC Sierra
Samsung gas dryer dv350agp/xxa have lights come on but is not working
It could be that you have a broken belt. Can you heat a motor running? Try placing your ear to it when you turn it on, if you can hear the motor running then remove the back panel and see if the belt is in tacit.
Best of Luck
'RR
May 15, 2014 | Samsung DV350AGP Gas Dryers
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Jonway eletric start and lights problem.
Recommend contacting your nearest authorized service center directly or online here:
http://www.jonway-motor.com/contact.html
Feb 03, 2018 | RTO Gas Motor Scooter 150cc
I HAVE A YORK STELLAR PLUS,MODEL PEUDD12N09501C 15 YEARS OLD. THE AIR INDUCTION MOTOR RUNS FOREVER. THE AIR INDUCTION MOTOR COMES ON , THE THE THERMOSTAT CALLS FOR GAS, THE IGNITOR LIGHTS THE GAS, FURNACE...
Check the filters first, then check for blockage in the return or supplies. An easy way to do this is by putting your hand in front of the vents to make sure accurate airflow is there. Your furnace has limit switches on it that detect heat, and if heat is getting trapped inside the unit to much, you will trip these switches and the blower will just run forever. Then you have to reset it or wait forever. But try those few things first. Hope this helps.
Nov 26, 2009 | York Yankees Bedding MLB Comforter
Gas gauge light comes on, how much gas is left
i have a 97 eclipse and when my gas light comes on i have 10 to 20 miles until i run outa gas. depending on how you car runs and if it is turbo or not. on a non turbo 420a motor w/ a 5 speed i can do this.
Nov 24, 2009 | 1996 Mitsubishi Eclipse
Have a carrier dual gas thermal pump everything works fine diconnected thermostat to srew back plate into wall thermostat seem to work but can'T get ANYTHING going, funance , heat, or pump.
Blown fuse in Air Handler. It should be on the fan board inside the unit. 5 amp auto fuse replaces it and it will be ok. Russ. Happens all the time dont worry about it
Jul 18, 2009 | Heating & Cooling
97 Malibu. V6-3100. Starter turns engine, but car
I think you may have answered your own question. I would check to see if the fuel pump is turning on when you turn the key on to the run position. You should hear a buzz sound coming from the gas tank. I would start there.
Jan 15, 2018 | 1997 Chevrolet Malibu
Hello my name is veronacarrier 8000 weathermaker will not ignite
call the furnace repairman. you have a fairly easy repair but the parts are expensive
Dec 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
All electronic working but dryer will not turn on to dry
if you think you here the motor come on real lightly you have probly broken a belt the motor is turning but not turn the drum because the belt is broken
May 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Goodman GMS90703BXA Heater Logo
196 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
