Question about Sony SPP M920 Cordless Phone
Sony SPP M920 HANDSET INOPERATIVE
Sony SPP-M920 Trouble with the keypad. Some times pressed keys do not activate. Can't change from line 1 to Line 2, when line buttons pressed 3 appears in window. Have changed battery, light stays on but it does not charge.
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
SOURCE: unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Posted on Sep 04, 2007
leecom72
  • 4806 Answers
SOURCE: PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
Posted on Jan 21, 2009
  • 14 Answers
SOURCE: sony model spp-a941
it acts as if it cannot see dialtone. Try pluging in a known good working phone and cord into jack. if the known good phone works try just replacing the cord. and so on until you find the faulty element
Posted on Jan 22, 2009
Z1G ZA9
  • 122 Answers
SOURCE: Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Posted on Apr 23, 2009
I have RCA Dect 6.0 two handset keys locked on one. How do I unlock keys
Keypad lock To lock the cordless handset?s keypad: Press and hold [*] button for 2 seconds until you hear a beep tone, when the keypad lock is activated, shows on the display. To unlock the keypad: Press and hold [*] button for 2 seconds until you hear a beep tone. Or simply replace the handset on the charger cradle.
I'd put it back on the charger and see if that unlocks it.
Feb 23, 2016 | RCA Lands Phones
The cordless handset is not working
I suppose you put the handset back on the base unit so that they synchronise first.
Nov 29, 2013 | Sony SPP AQ600 Cordless Phone
,i have my load but it is always says check operator services everytime i try to send a message
If the message "Check Operator Services" appears on the screen of your mobile when you attempt to make a call/sms, you should:
Check if there's a number 2 on the left hand corner of your screen.
If so, press and hold the # (hash) key until you see the message "Change the Phone Line?".
Press OK. The message "Line 1 selected" should then appear and the number 2 will disappear.
Attempt to make a call.
Note: Line 2 is an option on Nokia mobiles that's selected by holding down the hash key and pressing OK. Vodafone doesn't support this feature. You can prevent accidental changing of lines by activating your keypad lock. On some handsets, you can do this by pressing "Menu" then "*" to lock the keypad. "Menu" then "*" will unlock.
May 05, 2011 | Apple iPhone 3G Black Smartphone
I have sony spp m920. I have had it for long time and it's really great. My problem is that the lcd on the handset is no longer working (it only shows fragments of numbers,etc.) this is the older model...
If the hardware/physical part is ok, then it must be the battery. Are there any screws to open the handset or a small compartment in the back where batteries may be?
kc
Mar 24, 2011 | Sony SPP M920 Cordless Phone
Problem with my handset identifying base phone
I can help you register the handset if it is functional. I am a former Sony Tech.
Hand lotion gets on the keypad and into the back of the rubber keypad. There is a conductive carbon on the back of the keypad to short the circuit board when you press the key. Oil makes it stop working.
Parts are no longer avaliable but you can glue a small piece of alumimum foil on the rubber.
For Register Handset Error email me I will walk you through the steps.
digitalwoodshop@aol.com
AL
May 19, 2009 | Sony SPP-S2730S Phone
Buttons on Sony Spp-A2470 cordless phone are sticking.
There are liquid repair kits available to restore the carbon buttons on the back of each key How to repair remote control Tutorial ReplacementRemotes com The video explains it and is also a source for the necessary repair kit.
Apr 25, 2009 | Sony SPP A2470 Cordless Phone (SPP-A2470)
Telephone calls
If I understand this right, you can not leave your base station off the hook this will cause the line to be activated. Just leave it on the hook.
Oct 02, 2008 | Sony SPP-S2730S Phone
Handset broken, ticking
I lifted the handset off the contacts
May 10, 2008 | Sony SPP M920 Cordless Phone
Broken handset
The weakness with the handsets was that women using hand lotion or hair gel can get it on the front of the keypad. It then works it's way to the back side of the rubber keypad. The oil gets on the powder carbon on the keypad. The Carbon shorts the copper on the phone to activate the #1 or #2, etc. When the oil mixes with the carbon the key no longer works. I replaced many keypads until Sony Supplies ran out.... A cheap home fix would be to open the handset and clean the #1 key and the circuit board. You can try the keys but if they don't have any carbon on them you can buy liquid carbon at Electronic Stores OR just paper punch a circle of alumimum foil. Glue the foil on the key with thin glue. Works....
AL
Jan 03, 2008 | Sony SPP-A2780 Cordless Phone System
Sony SPP-M920
The numbers have rubber keys and on the back is a dry conductive carbon to short the keys.
To fix, you can try to clean it or glue a small piece of aluminum foil on bottom of the rubber pad. They sell a carbon coating in a small bottle too.
AL
Jan 01, 2008 | Sony SPP M920 Cordless Phone
Sony SPP M920 Cordless Phone Logo
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
