Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
All panel lights are flashing. the machine also buzzes. door will not open. clothes are trapped.
  • 909 Answers
I have noticed on both bosch and another brand, that if the lights flash, the board is defective and needs to be re-programed or replaced.Not sure if you have someone who can reprogram the ic in your board where you reside.
Posted on Nov 13, 2009
Washer will not turn on.
If the Add A Garment light is on, try this: the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point.
May 21, 2013 | Washing Machines
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
My door won't open on my daewoo airpower washing machine. My clothes are trapped!
unplug the machine for about ten minutes and then try to open the door after you plug it in. If the plug is not easily accessable, locate the fuse in the fuse panel for it. i may add after you have interupted power to the machine, you may want to try opening the door then.
Jun 12, 2011 | Washing Machines
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Jul 19, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
E13 and clothes are trapped
try setting the knob to the stop position, turn off the power and pull out the plug and wait for 2 mins and it should open.
Sep 18, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 30, 2009 | Asko W6441 Front Load Washer
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
WHIRLPOOL DUET FRONTLOAD WASHER
I had similar problem, the front door seal can trap small items,socks,handtowels. I didnt figure this out for some months, each load of clothes had a foul, mildew smell, Check door seal for trapped clothes, run intermittent cycles with bleach only, no clothes, be sure to leave door open when not in use to air out , this will reduce smell.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
232 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
