Question about Veo Observer Network Camera
I wite wrong firmware to my 602 wireless VEO camera
Hello !
i write 416 firmware from 601(wired camera) to my 602 wireless Veo Camera ! now i cannot see it in the veo seup utility animore,the light is always open and the litle display always off ! what shall i do ? here i don't have support because i take it from another country my country we don't have Veo Camera distribuitor !
so what shall i do ? how can i repair it ?please help me ! or my yahoo id messenger : florins36
  • 327 Answers
SOURCE: veo stingray
Download the latest drivers here
Posted on Nov 05, 2007
SOURCE: veo observer firmware
Posted on Nov 17, 2007
  • 19 Answers
SOURCE: Veo Stingray - with no disk
This fix will work for all of the VEO Stingray problems because it gives a good driver download site and it tells you step by step how to get your cam to work with VISTA Good Luck and let me know if this fixed your problems.
1.Go to this site and download the driver you need:
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam.
This works with all of your programs that vista will not run.
Posted on Dec 31, 2007
SOURCE: Veo webcam drivers
Have a look at this link. It explains how to install the driver on Windows Vista, but also includes links to disk images at the bottom.
How to install a Veo Advanced Webcam on Windows Vista
Posted on Jan 12, 2008
SOURCE: Vista driver for Veo Mobile Connect personal PC web camera
Sorry guys...VEO has went under, out of business, etc. Their site is gone, their drivers are gone, and products are abandoned.. Sucks doesn't it?
Posted on Apr 08, 2008
  • 268 Answers
SOURCE: need veo webcam driver
You can download the vista driver for the cam from here
Good Luck.
Live, Love, Laugh.
Posted on May 11, 2008
0 characters
1 Points
VEO observer hard wired version
Did you configure the webcam to be accessible over the internet? The IP address that you are using in your home network for the cam is only valid there (I assume you are running on a workgroup).
Jan 25, 2008 | Veo Wireless Observer Network Camera
Wep key for veo network camera
Your wireless access point or router is using WPA encryption. The VEO can only handle WEP encryption and its likely to be a hardware limitation - I doubt a firmware upgrade would appear for this. One solution is to change your network to WEP or open. Another is if you are running OpenWRT on you access point or router, you could possibly set up a virtual wireless LAN for your camera(s) using WEP while maintaining  your WPA set up for other wireless clients.
Sep 04, 2007 | Veo Wireless Observer Network Camera
VEO Wireless Observer RS232 serial cable help please
PC Serial port - Stereo jack
Pin 2 - Ring
Pin 3 - Tip
Pin 5 - Sleeve
Aug 20, 2007 | Veo Wireless Observer Network Camera
Voe observer down
Can you help me? I have an Observer camera too. And I have the problem "no response from camera" (Veo Observer Studio) and I can't reach the camera via Explorer too (the page dosen't exist).
Earlier it is working well except the remote access. I try it resolve and came the problem: "no response from camera".
What was the solution at your camera?
May 29, 2007 | Veo Observer Network Camera
Veo Observer network camera
Make sure that you are using Internet Explorer 5.0 or higher. If you are experiencing problems, try upgrading to the latest version of Microsoft's Internet Explorer from the Microsoft webpage at: Method A: 1) Go to C:\Program Files\Veo Observer Studio and delete the files: xrlknc.dll and xrlkncd.dll. 2) After the files have been deleted, try using the Veo Observer Studio again. --or-- Method B: 1) Uninstall the Veo Observer Studio from your computer. 2) Download the latest version of the Veo Observer Studio from our webpage at: if it still has the same promblem refer to your display or the grafix recommendations
Oct 15, 2006 | Veo Observer Network Camera
Oh dear!,Wireless is a pain, could be your firmare needs upgrading if it isn't already,(this is from 2003) you can download it here If not check it's ip address is showing up in the router. Also there may be interference from other appliances or walls and objects; causing it to loose it's wireless connection.
Oct 11, 2006 | Veo Wireless Observer Network Camera
Veo Observer Network Camera Logo
Top Veo Webcams Experts
micky dee
Waheed Hudewale
Are you a Veo Webcam Expert? Answer questions, earn points and help others
