Question about Canon PowerShot S2 IS Digital Camera
Stopped focusing properly. Now get only black when looking through view finder or on screen. other features seem to be working correctly
  • Canon Master
  • 4,738 Answers
A stuck shutter is a common failure mode for some model digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Nov 13, 2009
Out of focus pictures when shot with view finder
I had a problem similar to this. Try taking off your glasses or removing your contacts and try again. Best of luck.
Nov 23, 2013 | Canon EOS 60D Digital Camera with 18135mm...
How do i set up eye pieces and focus lenses?? Instruction manual came in chinese with no translation and we are begiiners!
During the day:
1. Point to a far (1000 meters or more) object
2. Insert the lowest power (highest number) eyepiece e.g. 25mm
3. focus on the object.
4. Align finder to match what you see in the scope.
At night.
1. Put scope out and let it reach the temperature of the outside.
2. Point finder to the moon (1st object you should always use to check scope and finder alignment)
3. Use the same low power eyepiece.
4. If everything seems fine, switch to a higher power eyepiece and enjoy the view. You may have to slightly adjust the finder to align with the main scope.
If the views are blurry, the telescope may be out of collimation. Look on the internet for generic collimation instructions.
If this still did not help. Throw the scope out! Its probably a piece of junk and will only discourage you.
Dec 12, 2012 | Optics
When I take a picture with the Canon Rebel, it doesn't focus in the view finder, but when I look at the picture after it has been taken, it is clear and in focus. Why can't it looked focused when looking...
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
Nov 29, 2010 | Canon EOS Rebel XSi Digital Camera
When I look through the viewfinder on my Nikon D40x it is blurry and looks out of focus, but when but after I take the picture it is clear on the lcd screen. Is there a setting I can change or is something...
Adjust view finder focus as you will see setting there, to view correct focus in view finder itself.
Camera is just fine because it is taking good focus pictures.
Oct 17, 2010 | Nikon D40x Digital Camera
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Can not seem to focus when we look through the lens we just see the bk=lack sky we cannot seem to see anything
try this:
see the mini scope on top of the telescope?--that's called the finder scope--
you look through that to see what the telescope is aimed at, just like what a sniper does before he pulls the trigger.
put in the lowest power eyepiece you have in the telescope, the one with a high number on it.
it's a good idea to align the 'finder' with the telescope during the day time--it's much easier.
if your telescope and finder scope aren't aligned properly, aiming your telescope at any target will be off and you'll just get frustrated.
to do this, look through your finder scope and pick a far away target, put in the lowest power eyepiece you have, that's the one with a high number--
high number = low power = a nice big view in the telescope.
low number on eyepiece = high magnification, like a zoom lens.
always use the lowest eyepiece first, then work your way to higher magnification, if you want to get a closer look at your target.
use lowest power eyepiece in telescope--> look through finder scope -->focus the image--> switch to higher power of eyepiece for a closer look at your target.
practice this during the day until you're comfortable, then try it at night.
try the moon, it's a nice big target
you can also use binoculars to check out the night sky.
you can try using 7x35 or 7x50 binoculars.
you see a lot more stars and it gives nice big views of the stars and constellations...and the moon...
hope this helps :D
Jul 30, 2009 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Picture in View Finder perfectly clear, but out of focus
I would check IS(image stablization) setting and continous shooting setting to make sure these features are turned off. You want to experiment with different IS settings and definitely turn the continous shooting mode because the continouse mode may not focus 100% in order to shoot multiple shots. Hope this helps. -James. P.S. In my case it was too difficult to distinguish the quality of focus in the VF or LCD so you may not see the focus issue on them.
Apr 12, 2009 | Canon PowerShot S3 IS Digital Camera
Finder focus problem
is there a little slider type bar/switch/button on the finder, most cameras have them to compensate for different peoples eyesight. if there is, look through it, put camera in auto focus and when its focused, look through finder and move bar/switch... til pic is clear
Sep 21, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
The view finder does not wotk
Try pulling out the eyepiece, it will reveal a switch that controls the focus, it maybe the problem, good luck
Aug 13, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
