Question about Samsung CLP 300 Laser Printer
How can I print without margins?
when I bought this printer the solder told me it can print without margins (white frame). it's not true, the assistance center told me they don't know why, they have already changed one printer, but the problem is the same.
are you able to print without margins? how? thank you for your answer!
p.s. sorry for my english, I'm italian!
  • Anonymous May 30, 2008
    Hello, Just bought a samsung clp-300, I need it to print borderless, i have spoaken to samsung technical and they say it will not. Is there another way to get it to print borderless, another program to download?
  • 417 Answers
You may all you need to do is open the properties of the printer and check that there maybe a setting that says margins or you are looking for edge to edge printing. Check that then you should be able to print without margins. Also within MS word click file then page setup and check the margins in that as that can also cause your fault.
Hope this works
Thanks J
Posted on Jan 20, 2008
6ya staff
SOURCE:
Printing without the white side lines
I think the problem is not with your printer but with page set up. Try going into settings for your printer and reduce the margins.
Jan 03, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
Printing Phaser 8550
that is a part of that printer design. Something sadly you can not get rid of. Believe me, I have tried, and Xerox engineering told me that is part of how the machine is supposed to work. Wish we could eliminate that.
Mar 26, 2009 | Xerox Phaser 8500/DN Printer
I need to print a programme on microsoft publisher without the white border around the outside so basically full page but it wont do it any ideas
Maybe it is a printer limitation. Some printers just will not print full pages, even if you set the margins to 0mm on all sides. Try other printers.
Oct 12, 2008 | Computers & Internet
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Jun 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Margins want gone
full bleed, eh? that will be in the print settings issue..make the margins 'nil' and you might get lucky. that's usually a custom print job, by the way.
Feb 06, 2008 | Dell 3110cn Laser Printer
Samsung CLP 300 Laser Printer Logo
1,067 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
