Question about Nokia N70 Cellular Phone
When i want to clear the timer on nokia n70 it
When i want to clear the timer on nokina n70 it asks me for a lock code. What is the lock code?
How can i open my nokia n70-1? it always appear the unlock code. this is the IMEI code: 0539240. please help me. thanks a lot.
Your phone is locked with a network and hence when you insert other networks it asks for the unlock code.You can approach Onlinegsmunlock.com and get the respective unlock code to open your Nokia N70-1 from its locked network.
Aug 17, 2013 | Nokia N70 Cellular Phone
How to unlock my n70
Hi code is the best method to unlock your nokia N70 mobile from network lock .To get code visit Theunlockarena.com here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Nov 29, 2012 | Nokia N70 Cellular Phone
Nokia n70 unlock code
HI visit Unlocking4u.com to unlock your Nokia N70 mobile from network lock .Here they ask you the network name to which your mobile is locked and the imei number of your mobile .Finally they send you code to unlock your mobile.
Sep 02, 2012 | Nokia Lands Phones
Lock code to clear timers
If you have never set it, the default security code on all Nokia phones is "12345" - try that.
Jul 09, 2009 | Nokia 5800 XpressMusic Smartphone
Locked phone n70
hi there,
here you try to follow some procedure how to unlocked your mobile and i hope it will help you to solved it..
any further question you can log on this site....
http://gleez.com/articles/did-you-know/nokia-secret-codes
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Thanks.
Feb 17, 2009 | Nokia N70 Cellular Phone
Lock code
i changed the 12345 lock code for my N70 to anther number. I didn't record it and now I have no idea what that number is. My N70 is asking for the lock code but I don't remember it. Can you please help someboyd who is a Guru out there. Thanks and stay blessed.
Sep 28, 2008 | Nokia N70 Cellular Phone
Nokia n70
if you enter the wrong code in a few times it will ask for a puk code call your service provider forthe puk code and it will reset the code
Jul 19, 2008 | Nokia N70 Cellular Phone
Forget the phone lock code
If you need the SIM Pin number to switch the phone on, then you have to enter any Pin number 4/5 times, then the phone will request a PUK number. This number was on the plastic card that your SIM card was attached to. If you don't have it, only your Network Service Provider can supply it to you.
If it's the Security code you need, to get into certain settings IE. erasing received calls, missed calls, timers etc... the Nokia default is 12345 if you didn't change it, but if you did change it and you've forgotten it, let me know, I'll tell you how to retrieve it.
Mar 06, 2008 | Nokia N73 Cellular Phone
Nokia N70 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
