Question about AEG Washing Machines
AEG Electrolux Lavamat Turbo 16830 stopping during wash programme
I have an AEG Electrolux Lavamat Turbo 16830 washer-dryer. It will work on a wash programme for up to 2 minutes, then stop.The pause button will flash and the door light will change from green to red. I can get it to do a full programme once the drum is full of water, this I achieve by turning the washing machine on &off about 8 times, so the drum fills up a tiny bit at a time before stopping. Please help.
SOURCE: hi,i have an indesit wil
sounds like motor carbon brushes need replaced .
Posted on Sep 25, 2008
SOURCE: AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Posted on Feb 01, 2010
SOURCE: AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Posted on Apr 08, 2010
  • 174 Answers
SOURCE: aeg Lavamat 64840 programme stops at 1 minute.
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
SOURCE: i have a aeg lavamat turbo washing machine .when
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Posted on Jul 20, 2010
Aeg lavamat turbo 16830
start at the beginning,, check your fuse
Jul 16, 2013 | Washing Machines
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
Apr 03, 2013 | AEG Washing Machines
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Electrolux Lavamat Turbo 16830 Washer/Dryer but dryer not working
Has the little belt on the dryer turbo come off? or is the turbo seized - it should turn freely by hand. You may need to replace the turbo fan if the belt keeps coming off - the pulleys can get out of alignment, ie not running parallel to each other - they tend to be cheapo plastic construction these days. Could also be dryer elements or thermostat problems, or blockage with lint causing reduced air flow and overheating - but check belt first.
Nov 28, 2017 | Electrolux EW1209i Front Load Washer /...
Jul 20, 2008 | Washing Machines
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
479 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
