Question about Hotpoint TDC32 Electric Dryer
How do I remove/clean the filter on my Hotpoint Aqurius condenser drier?
  • Hotpoint Master
  • 3,463 Answers
There are 2 filters to clean on this dryer.
1 is at the bottom front left, pull all the way out, and wash clean under running water, quite in order to do this.
The second one is at bottom front right, again pull out to clean, but do not use water on this one.
Some dryers also have one located inside the door opening, pull out to clean if yours has one.
Please leave feedback.
Thanks
Posted on Nov 13, 2009
How do i clean filter at bottom of hotpoint condenser tumble drier. Water coming out at base.
if you mean the condeser itself ...it just pulls out..........best way to clean is with a hosepipe gets all the fluff out....but.if you have water leaking...........best bet is to check the tank at the rear.....at the bottom of the base.....the tank operates via a piece of plastic or fibre which floats up as the tank fills.....which inturn hits a micro switch
...setting the pump going to pump the water to the empty tank........check the float first.........
cheers
May 02, 2017 | Hotpoint Dryers
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
Hotpoint WD440 creases clothes badly & takes ages to dry
This sounds like excess steam in the drum. Check that the drain filter is clean as washer driers rely on cold water being taken in to cool the condenser tank during the drying cycle. If the filter is clear, the tank may be blocked with fluff. You have to open the machine a look for a big plastic tank, usually down the right hand side.
Dec 11, 2009 | Hotpoint Ariston WD440G Front Load...
PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD 129-ON DRY CYCLE CLOTHES COME OUT STEAMING AND WET. PLEASE ADVISE
If the clothes are coming out hot and steaming, then the water from the clothes is not condensing, it could be a blocked condenser, which will have to be removed and unblocked and cleaned.
The other possibility is that there is no cold water coming in on the drying cycle, this can also have the same effect.
Hope this helps.
Dec 03, 2009 | Hotpoint Washing Machines
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Our hotpoint aqurius wont rinse properly on its last cycle it doesnt empty properly
Most probably the pump has partially or completely siezed/failed.
Early machines had the pump in a position where condensation dripped on to the motor and over time caused the motor to seize.
Never worked on a modern Hotpoint but I suspect even if not due to the same cause, pump not running is your best bet.
Sep 07, 2009 | Washing Machines
Dryer not heating up
I hate to tell you but get ready for more problems with this drier, it has a bad track record. In some cases cleaning the condensor out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, this is under the bottom panel at the front of the tumble dryer, you simply pull the panel down, undo the condenser and pull it out (it is normal for there to be some water in the tubes when you do this), you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier and empty the water container often. This curcuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later DRRXR
Feb 02, 2009 | Hotpoint Dryers
Hotpoint TDC32 Electric Dryer Logo
276 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
