Question about GE GSL25IFR Side by Side Refrigerator
Model gsl251grb water dispenser stopped working. r&r filter no help. turned temp down in case froze, no help. can hear motor run. ice maker works. help
  • GE Master
  • 1,606 Answers
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Posted on Nov 13, 2009
  • Mike Smith
    Mike Smith Nov 15, 2009
    If frozen in the door , there is a dispensor water line heater , pt # WR49X10173 , that comes with instructions .
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Ice maker not making ice and water is not flowing
this could be several items so will go down the list in order... 1st you need to make sure you have a good clean filter or that it has been changed recently... sometimes removed and reinstalled will also help... 2nd do you have 120 volts ac current to the water valve when called for water example" someone pushing the water dispenser handle while you test... if you have 120 volts and no water coming you have a bad water valve... if the dispenser is working but the ice maker is not filling with water they do have dual water valves and one side can actually be bad... before shooting the water valve down though if your getting water to the dispenser but not to ice maker make sure the unit is actually calling for water... on most of these ice makers there is a gear motor on the front part of ice maker there will be a white cover over the front of unit remove it and turn gear motor makes sure it is not broke.. is there frozen water in ice maker if so may be the heater on ice maker is bad... if no water again before shooting down water valve make sure the fill tube coming into ice maker is not froze up...if it is froze up most likely you have a weak water valve and needs to be replaced due to not seating properly.... hope this helps hard to diagnose when not sure what all you have already tested or not...
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser not working
I had the same problem. Your water line is frozen. Turn off your freezer and the water line will unfreeze and it will work. You can see about putting in a heater on your water line. There have been mixed reviews on whether or not it works. The water line just froze again, so I may try the heater.
Apr 28, 2010 | Viking DDSB483 Side by Side Refrigerator
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Ice continues to be made, about a week ago, the part that turns the ice to crush it or dispense it doesn't work, it also takes about 2 minutes when water is activated before it will finally dispense, all...
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again. It it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Aug 21, 2009 | Refrigerators
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GSL25IFR Side by Side Refrigerator Logo
274 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
