hi,
it is not 64 MG, its 64MB, it has a very low memory capacity, this memory card is used for still snaps, you can find the snap button on the cam, this cam will not support much bigger GB memory sticks.
If the two 512 meg sticks still work in the same slots, then you either got bad memory or some that is incompatible. Return the memory to were you picked it up, and get a different brand. Also double check that your are using the correct memory for your system. This infomation can be looked up on most memory manufature websites (example: Crucial or Centon).
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
I had such an issue with my 16GB Kingston it just died after 2 month. But usually it comes with at least 5 year warranty. So I returned mine and got new one instead. My luck that I had my files backed up. Try to change your kingston if it's completely undiscovered by your PC. But try it on another PC or Mac first. Good luck!
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
I had the same questions. Eventually, after seeing sellers selling the 1GB Olympus type M card as compatible for the A210, I decided to take the chance. I've only used the 1G for a while, but I've seen no problems with it and the A210
