Question about Epson Office Equipment & Supplies
My epson sx515 wont work on windows 7 32bit can u help
Try here
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX515W/Drivers-Support?_DARGS=/jsps/support/modules/mainContent.jsp#
for latest drivers.
I had to install on W7 other day, my workaround was to install the wireless part on an xp machine, then add the printer (is the network setup software crashing W7?)
there is a piece of paper in the documentation
http://support.epson.net/win7/info.html
this may be helpful
Posted on Nov 14, 2009
3 Suggested Answers
  • 121 Answers
SOURCE: EPSON LQ 1070+ PRINTER DON´T WORK ON WINDOWS 7
Unfortunately, no Win7 drivers exist for this printer.
You are better off running a Win98 or XP virtual machine on Win7 (like in VMWare), and installing your printer that way. There's no guarantee that would work, but it's at least one more thing to try.
Good Luck!
Posted on Jan 24, 2010
  • 62 Answers
SOURCE: epson stylus c60 printer not working in windows vista 32bit
Hello
Try with this link and you are going to get the resolution
http://asia.cnet.com/downloads/pc/swinfo/0,39000587,50002366r-39494464s,00.htm
Thnaks & Regards
Posted on Apr 05, 2009
Windows 7 epsom sx515 printer, driver detective installs sx510 driver
Please. Do NOT rely on 'Driver Detective'.... !!!
Just un-install the software from this and the driver and download
and install the original Epson SX515w printerdriver and software!
Oct 17, 2011 | Office Equipment & Supplies
Do you know the combinations of buttons to press on EPSON SX515 TO RESET INK PAD COUNTERS
download the SSC Utility from the net. Its free and there you will find the counter resets.
Aug 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Usb printer cable male connection is too small for epson sx515
Hi i'm Basti,
What you need is an A to B type of USB cable. You can purchase it from your local computer stores.
Hope this helps. Cheers!
Feb 25, 2011 | Computers & Internet
Have just bought a reconditioned Epsom sx515 wifi printer has come without instructions was wondering how to install on a netbook ?
Need the model number to provide more help, but you can go to any Epson wesbite (Not all models are available in ervey country); click on Drivers and Support; then use the Product Finders or search the product menus to find your product. You should be able to find drivers, User Guides and Manuals.
Here is the Canadian site
http://www.epson.ca/cgi-bin/ceStore/support/SupportIndex.jsp?BV_UseBVCookie=yes
Trust this is helpful. Please don't forget to vote. :)
Dec 11, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson SX515 will not work wirelessly with Netgear WNR 834b v2
This printer cannot assign ip's to the router only the router is able to assign.
Apr 20, 2010 | NetGear WNR834B RangeMax NEXT Wireless-N...
My dx4050 wont work with windows 7
search for " driver for dx4050 for windows 7 " on google and install it
Oct 31, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Installed my SX515 Epson printer and it will not connect with wifi
0 false 18 pt 18 pt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-ansi-language:EN-US;} This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable.
1) Using the Control Panel on the printer, press the Spanner/Screw driver button.
2) Scroll though the menu until you see Network Settings & press ok.
3) In the following menu select Wireless LAN Setup.
4) Then select Advanced Setup.
5) Then select manual Setup & press ok.
6) This guide assumes you are connecting through a router via Wi-Fi, in which case you will need to select Infrastructure Mode and then press OK.
7) Select Search SSID & this will search for your wireless network.
8) If your wireless network is showing, make sure it is highlighted then press OK.
9) Now you will need to enter the encryption type, this will depend on the length of the wireless key. WEP 64 Hex (10), WEP 64 Alpha (5), WEP 128 Hex (26), WEP 128 Alpha (13). Any router that has 8 characters I would normally recommend selecting WPA PSK TKIP UNLESS you know that the key is WPA PSK AES.
10) Now you will need to input the security key depending on which type you have, as advised above.
11) Once the key is in correctly you need to press OK. You will then see a Confirm Settings screen. Press OK on this screen and YOU MUST WAIT 30 SECONDS for the printer to establish a wireless connection with the router. After the 30 seconds please go down to Confirm Settings and press OK. This will tell you if it has successfully connected to the router. At this stage you need to make a note of the IP address. This normally starts 192.168.x.x
12) On the PC the printer will need to be installed, I recommend downloading the driver from here:
13) Once installed go to Start > Control Panel> Printers (This will vary slightly depending you version of Windows).
Right click on the printer, select properties (Printer properties for Win 7). Select the ports tab and add a new port.
When adding a new port select Standard TCP/IP, then click add new port.
NB The Standard TCP/IP port is recommended when assigning static IP address to the printer. (See router documentation on assigning static IP address).
If using a dynamic IP Address I would recommend downloading and installing the Epson net printer port. You can use a Standard TCP/IP port, however when the IP address changes communication between the printer and PC will be lost.
Setting up both port types are the same, once you select add port you will need to enter the IP Address, which we noted down previously from the printer. Once entered keep clicking next, then finish.
You should now be able to print over the network. To use the scanner over the network you will need to open Epson scan settings, (a separate utility to Epson scan) this will need to be set to network and contain the same IP address noted down earlier for the printer.
If you still have issues check your firewall and router settings, i.e. mac filtering etc.
Oct 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
4,545 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
