Question about Frigidaire FGF337EC Stainless Steel Gas Kitchen Range
The oven turns on but the burners don't. already cleaned them but no luck. he oven is receiving gas but not the burners.
  • 234 Answers
The only way the burners could not receive gas is if the lock-out is activiated (also known as: child safe mode) . Most people (when the burners do not work) say that they here the gas hissing from the burner but it will not light, hiwever you say that no gas is hissing from the burners, therefore must be the lock-out. To unlock, look in your operation manual because there are a few different ways to do this.
One common way is to hold a particular button for 3 full seconds; some models have a button with a lock picture, others tell you to hold the stop/clear button or the light button for the 3 seconds. If this does not activate the burners, you have a malfunction of the lock-out valve or the control board or a wire connection gone bad between these items, and this will require a techperson to trouble shoot it. GOODLUCK, MACGIVOR
Posted on Nov 13, 2009
Burners turn on sometimes as does the oven but then may not turn off
Hello, when you turn on one of the burner, can you hear some clicking while you turn on one of the burners? This is an electric ignitor, and when you turn one burner on all the burner ignitor will click.
It is possible, that you are turning your burners on the stove to quick. Take a look at one of knobs and you will see ignition--low---medium---high. To get the burning ignited the knob needs to be position at the ignition site. You'll hear it click-click-click and the burner will ignite.
Now, the oven. The oven ignitor is on a time delay. You will push the bake button and across the screen will say something like this "Please set oven temperature" You'll set the oven temperature to---let say 350 degrees---. Then the screen will say "push start button" then you push the start button to turn your oven on. Now, the screen will say "pre" this means that the oven is pre-heating the oven to your desired temperature. Before all this happens there is ignitor in the oven and it has a heater on the ignitor in oven. This heater will heat up to desired temperature and once it reaches the that temperature the ignitor will ignite and the gas will turn on.
Why--one would say for this procedure. The old kitchen stoves had a very bad habit of of flash over---that is gas will built up in the over and once the pilot light ignited the gas---wussh and it blow the oven door open. These ovens would sometimes huff too.
Therefore, take your time and your biscuit will be OK
I am sorry Sandan2. I didn't finish reading your question. Never mind on what I said here.
If the burners will not shut off sometimes, then there could a gas regulator problem.
One very important question. Is your kitchen stove using Natural Gas or LPG--liquid Petroleum Gas?
If it is using either type of fuel as mention above. It is very important that you contact Appliance repair person that is certified by the state that you live in that he/she is license by the state to work with gas appliances.
I wish you luck, but it very it important that you contact a certified Technician... Also, move the stove away from the wall and look behind it. There a black gas pipe and at the end is a brass valve, Take wrench and turn the gas valve off. The gas valve will have a stainless steel flex line attached to it, and the other end is to your stove. Don't use your stove.
If those gas burners and the oven are leaking gas. There is possibility to blow you and your family with your home up. Don't use the stove, Until you have it check out...please. GB you/your family...stewbison
Sep 07, 2011 | LG LRE30755ST Kitchen Range
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
The burners are not lighting Frigidaire Gas Range only 8 months
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a tappan gas range all the burners but one works when i turn it on. You can hear the flow of gas, and the oven doesnt work. what could that possible be
Mar 25, 2010 | Tappan 24 in. Freestanding Gas Range...
Stove top ignitors do not ignite but oven does.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The gas burners are not igniting when being turned on??? When the dial is turned the gas comes on but the burner does not lite - no clicking sound? Thanks for any help!
Feb 09, 2010 | Heartland 3635B Dual Fuel (Electric and...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frigidaire FGF337EC Stainless Steel Gas Kitchen Range Logo
89 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
