Question about HP DesignJet 488ca InkJet Printer
Hp 488ca cartridge error.
Hello, I've got an error on the cartridges group, no matter what i do, the error light keeps blinking. The cartridges are clean, all the contacts are clean, the printer was working last week(!!!). The belt is fine. It seems that is nothing wrong with the printer. What should i do next?? Not even a test page come out!
Regards,
L. Teixeira from Portugal
  • 9 Answers
SOURCE: HP PSC 1350v Check Print Cartridge Light
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge (office depot) I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Posted on Oct 29, 2007
  • 137 Answers
SOURCE: Cartridge errors on HP97 / bad TSR?
Hi Scott -
Sorry, I do not have any additional ideas as it seems you have checked things I would have suggested - cleaning the contacts. (I presume you did clean the cartrdige contacts in addition to the printer contacts.) The TSR may be correct but may be encoded incorrectly, which could cause an issue as this would make the printer "think" the cartridge was too hot or too cold. The printer will refuse to print with certain ID errors. A 10-tap will bypass this test as a diagnostic aid. Does the 10-tap show a "good" nozzle diagnostic? If there are repeating missing nozzle segments across all three colors it would indicate an interconnect issue.
If the cartridges are original HP cartridges I would check the warranty date (two years warranty from date of manufacture) as shown here. If the cartridges are still in the warranty period contact HP for replacements.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Jul 03, 2008
SOURCE: Remove and check color cartridge
the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
Posted on Jul 31, 2008
  • 399 Answers
SOURCE: hp dj3745
it means either there are pending documents in the print que delete them,if no pending documents remaining in the printque.
then either of the print cartridge is faulty.remove the cartridges 1 by 1 and check and see whether its blinking .
if the blinking stops after removing black cartridge the blck is faulty, or if,the blinking stops after removing the colur cartridge the colour is faulty.
if still blinking then both the cartridges are faulty.
thanks.
Posted on Sep 18, 2008
gisvc
  • 40 Answers
SOURCE: hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
Posted on Mar 30, 2009
Hp 1315v all-in-one printer will not recognize cartridge. Does anyone know how to bypass the coding that tells it to not recognize the cartridge?
This page addresses what to do if you get different blinking lights on the printer. Match up the blinking light on this page with the light on your computer. Then click the plus sign to expand the page and view the solutions. The solutions for blinking cartridge light are not easily pasted here and I can't bookmark to that solution.
Blinking Lights
One thing to keep in mind with ink cartridge problems is that the cartridge has a warranty as well. You might consider checking back with HP using the warranty on your cartridge.
Sep 29, 2014 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart 7400 once switched on goes to printer busy but will not print
HI,
Please reinstall your drivers.You can go to control panel,add/remove programs and uninstall your printer driver.
Sep 04, 2008 | HP Office Equipment & Supplies
I've bought new cartridges and it keeps telling me cartridge problem or cartridge appear to be missing; What can I do about this problem ? or do I have to return the machine to you for a refund or
Please install one cartridge at a time and close the cartridge access door to check if the error pops up.
Also inspect the T shape vent on all of the cartridges, which should be clear and not clogged.
While installing the cartridges, make sure there is click sound when you install it.
If issue still persists, contact HP Tech Support as it could either be an issue with the Printhead or the Printer hardware itself.
If you are in USA, please call 1-800-474-6836
Jan 10, 2013 | HP 564 XL Series Ink Cartridge Set for...
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Hp 3180 print cartridge light blinking
hi,
Mar 29, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Deskjet 1280 : The resume light keeps on blinking.
Can I get the reply now? I have a whole lot of documents waiting to be printed.
Oct 06, 2008 | HP DeskJet 1280 InkJet Printer
Hp dj3745
thanks.
Sep 16, 2008 | HP DeskJet 3745 Printer
HP DesignJet 488ca InkJet Printer Logo
156 people viewed this question
Seeker5211
Seeker5211
