Question about Electrolux Kitchen Ranges
Continuous clicking noise on Frigidare model glgf366abd range from control panel area. Control panel does not show anything. only burners work, nothing else. noise goes away when unplugged
  • 1 more comment
  • dobergefell Nov 13, 2009
    is the EOC board the display board? why not just replace it?
    should i just replace the board that has the controls on it? Is this the EOC board?
    clicking noise is definitely coming from timer panel which is manf by spitfire. I have it apart. So I should probably just replace the timer panel?
  • Electrolux Master
  • 19,396 Answers
Hi.
If the clicking noise is coming from inside the oven cavity, near to the gas valve, then the noise is coming from the igniter: PS470129 part 19 on diag 2.
In that case check that igniter is not grounded and that there is no contact on wiring harness.
The igniter can be tested in a rudimental way disconnecting one of the igniter contacts at time on ERC (timer) side.
If the igniter keeps sparking, then there is a contact, ERC board is good, and problem is igniter or wiring harness.
A proper test must be done by a tech, reading volts on ERC. Tests with hot power are not suitable for the user. Always disconnect power when working on the appliance.
If the ignitor is not the problem, then the fault is usually the Continuous clicking noise on Frigidare model - _.gifTimer control : PS977488 (part 20 on diag 1).
Before replacing ERC (timer), check that the noise is not coming from a stuck button on control panel.
Test summarily the ERC, looking for blown parts etc. If you can repair electronics you can grab the multimeter and test the part at component level.
Try disconnecting the igniter from ERC, and reattach power to see if you still get the click.
If a clicking noise is coming from timer board, then the timer board must be replaced.
The clicking noise is more often coming from igniter, check the igniter first.
Please, click on the diagrams below to enlarge the pictures.
Do not forget to give our solution proper feedback.
Many thanks.
G.
Posted on Nov 13, 2009
  • Ginko
    Ginko Nov 13, 2009
    If clicking noise is from timer panel, check connectors just in case, and then replace thi timer (
    PS977488
    that is what a technician onsite will probably do.
    At a workshop they will test the panel a bit more before replacing. thisis done reading voltages and having a look at components.
    If noise is from panel, then replace the panel.
    Regards.
    President:
  • 1,653 Answers
Sounds like you have an electrical short around the control panel or EOC. It could be somethinga s simple as aloose wire or the EOC may need replacing. You are best to call in a service engineer ASAP.
  • Karl Wright
    Karl Wright Nov 13, 2009
    Yes I would replace the control panel.
  • Karl Wright
    Repalce the Timer Panel.
Frigidare Model MEF352BFWA Electric Range
yes. first just check for any burned fuses on the control panel area..
let me know
Jul 30, 2008 | Kitchen Ranges
After cleaning the cooktop surface the "clicking"
I just solved the continuous sparking in my gas burner. I removed the control knobs and the rubber below those knobs. Gave the rubber and the area below it a good clean using kitchen and bath cleaning wipes that I bought from Coles. The key is to remove the water and grease from the rubber and the area below it. Good luck!
Mar 24, 2011 | GE Profile JGP636 Gas Cooktop
How to i stop all 5 of my cooktop burners from sparking?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Aug 10, 2010 | Cooktops
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
Frigidare range glgf376dsm display not working
That's common for the burners to work since they & ignightors have nothing to do with the control board. The oven light is also run by the control board. Before replacing the control board, make sure you have both phases of the power coming in. One 1/2 of the 220 operates the burners and the other phase is the power to the controller. The controller then put both phases on the heating elements. There should be a tech sheet and schematic on the back of the stove or under the hood where the controller is. Good luck
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Oven not heating KitchenAid KERC506HWH3
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
Nov 16, 2007 | Kitchen Ranges
Kitchen Ranges Logo
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
