Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
My saniplus macerator has stopped working. The 240volt feed going to it is ok.
  • Anonymous Mar 22, 2014
    how to replace the macerator capacitor
  • 2,237 Answers
Does it make any noise? the valve switch may no be working. if you hear the motor buzzing but not working, something is jammed in there. either way, be ready to get your hands dirty.
Posted on Nov 13, 2009
Whining noise after the flush is filled and the noise keeps on but if the macerator is given a gentle kick the noise stops! Do I need a new Macerator?
sounds like there could be a blockage inside which is effecting the pump or the float switch look on the saniflo website for instructions how to clean etc or phone there tec department
Dec 09, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Do you think saniplus would be compatable with this toilet http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170533516585&ssPageName=ADME:B:EF:GB:1123
The toilet that the Saniplus uses is a rear discharge toilet, the spigot is 3" ID and 4" OD from center line of spigot of the toilet to the floor is 7 1/2". If the toilet you chose has those dimensions then it will work ok.
Aug 30, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniplus draining in pulses
When you flush the toilet, the Saniplus will turn on and off once or twice, this is normal. If it turns on 3 times or more then could be a problem with venting or the discharge pipe installation may not be properly installed. But when you run the sink or shower it will turn on and off constantly, this is normal. The Saniplus pumps out the water as it comes in.
Jun 20, 2010 | Saniflo & Saniplus& Macerator Pump
This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Dec 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Macerator
unfortunately saniflo - nor any one else publishes a saniflo repair manual. You can get tips online - but thats as far as it goes.
Dec 10, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Hi i have a saniplus macerator unit hums but
sounds like an obstructed unit - you would need to remove the impeller cover at the base to check the pump - i'm assuming youve already checked the blade unit at the top (be careful here - i use a screwdriver - not my finger) could be that a simple cleanup and acid descale would be all thats needed. try this first then start looking deeper.Humming indicates motor is ok - but dont let it run continuosly - you dont want to burn out a good motor.
Dec 05, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
The small pump runns all the time We need to switch of the power to stop the pump. But it works OK
Sounds like the float is stuck up. Thump the holding tank a couple of times with your hand to see if it wiggles loose. May have to open it up to see. If a tampon was put in the toilet it could be causing this problem.
Oct 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
The saniflow unit is only 4 months old at first it was ok now it has started making a loud grinding noise when anything is done,toilet,sink or shower
There is no nice way to say it. You are going to heve to open it up and look in it to find what's stuck in the macerator mechanism.
Oct 16, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
System not flushing and motor cut out.
Motor may have been jammed and notw burned out.
May 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
2,105 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
