Question about Motorola Mobility MOTORIZR Z8 Cellular Phone
One button presses repeatedly - Motorola Mobility MOTORIZR Z8 Cellular Phone
Have entered the code on the radio but dont know which button to press to get the code to activate
It is usually Button 5 ....or occasionally Button 6
===================================== Ford Code EntryInstructions Once the unit has been turned on the display will show 'CODE - - - -' Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit To save the code press the [ 5 ] key to accept. The set should now operate.
Feb 15, 2011 | Ford Car Audio & Video
Unlock ford car radio. have code.
can you give the number or name of the model
Apr 05, 2008 | Car Audio & Video
I hav the code ect (Blaupunkt 300 ina astra van), now need to know how to install / reset radio
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Jan 21, 2011 | Blaupunkt Car Audio & Video
Put code in to my ford radio which button do press to enter
usually the 5 Button (occasionally 6 Button)
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Oct 03, 2010 | Metra 86 5618 Ford Radio Removal Tool
I have pin for ford radio but no manuel
TO ENTER THE SECURITY KEYCODE FOR A FORD
Switch the ignition ON using the key
Switch Radio ON - Display Shows CODE with " - - - - " flashing
Press Preset Button " 1 " repeatedly for 1st Digit of your KeyCode
Press Preset Button " 2 " repeatedly for 2nd Digit of your KeyCode
Press Preset Button " 3 " repeatedly for 3rd Digit of your Keycode
Press Preset Button " 4 " repeatedly for 4th Digit of your Keycode
If the display now shows the correct KeyCode number then
Press Preset Button " 5 " to Enter
Providing your KeyCode was correct then your radio / cassette or CD should now be working
Aug 29, 2010 | Ford Car Audio & Video
How do i put the code into a vauxall astra radio
Press Preset Button " 5 " to Enter Providing your KeyCode was correct then your radio / cassette or CD should now be working
Oct 07, 2009 | Car Audio & Video
How do i unlock the samsung dvd-l200
1) Turn on your player
2) With no disk inside press repeat on your remote ( do not press repeat ab ) . Repeat is a separate button
3) Press up arrow
4) Press down arrow
5) Press right arrow
6) Press left arrow
7) by now you will see a number on the screen.
8) now press the up arrow button until you read the number " 9 " on the screen
9) press the " repeat ab " button
Oct 16, 2008 | Televison & Video
Gpx tvp75
To repeat one track, press the REPEAT Button once while the track is playing. The REPEAT Indicator will flash
To repeat another track, press the SKIP/SEARCH DOWN or SKIP/SEARCH UP Button
To cancel Repeat One Track, press the REPEAT Button twice. The Repeat Indicator will no longer flash
To repeat the entire disc, press the REPEAT Button twice while the disc is playing. The Repeat Indicator will illuminate
To cancel Repeat All, press the REPEAT Button once. The REPEAT Indicator will no longer illuminate
Sep 16, 2008 | GPX TVP75 5 in. Portable Television
Trutech clock radio - forgot how to repeat
Press the repeat/random button until it shows "r1" will repeat the current track.
Press the repeat/random button until it shows "rA" will repeat the entire CD.
Press the repeat/random button until it shows "rd" will play all tracks in random order.
Press the repeat/random button until nothing shows will cancel repeat/random playback.
Aug 20, 2008 | TruTech Clock Radio
I need to know how to reset the time/date on the answering
Hold the repeat button for about 2 seconds. The unit will say Time is not set then Monday 12:00 AM. 'press and hold the on/off button to advance the days. After the day is set,press the repeat button to set the hour. Press the repeat button to set the minutes. After the minutes are set,press the repeat button to set AM or PM. Hope this solves your problem.
Aug 14, 2007 | Conair TAD2018CG Digital Answering Machine
Motorola Mobility MOTORIZR Z8 Cellular Phone Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
