Question about Acer Aspire M1641-U1521A PC Desktop
I have a M16141 pc the motherboard is defective I need to replace it. Questio is what motherboard can I put into it beside the one coming from acer???
  • 535 Answers
When u buy the board from that person give u replace meant and the u can also sand it direct in company for replacement if problem is in the mother board then acer is replaced the mother board and give u new motherboard
Posted on Nov 14, 2009
I have a Dell Vostro 410. It would not turn on - would just blink amber light and go "ping, ping" - So I had a technician come and he said the motherboard was bad - we put in new motherboard -...
Yes the motherboard is faulty. But it hasn't died on its own, it was damaged by something else in there - most likely the power source is defective and it has effectively fried the boards. The technician should have tested it before replacing the board. Call it again, make him test the source in front of you and if it's defective have it foot the bill for the repair.
If the source is OK then something else that is connected to the pc is defective so multiple test will have to be done.
Sep 14, 2011 | Dell Vostro 410 Desktop Computer
I have an 17" aopen
Hello
You've said that there is no start up with your hdd even you hdd is defective your CPU will turn on and have display in your monitor try to turn your computer on then push the button delete or a f1 button it depends on your bios that you have using. If your PC tun and display the bios it means your motherboard is good. Then in the bios set up put it in the main section you will see if your HDD is detected by your PC if not then you HDD is defective o have a lose contact on its connectors.
If you don't have a display try to check if your CPU have a video card. Turn off your PC then pull out VGA connector that are connected to your computer then pull out the Video card in your motherboard which connected to a PCI slot then tun on your pc using the on board VGA connector which is located at the back of your CPU which is beside the parallel port and on the lower of the mouse and key board connectors. If the problem is still there try to clean your Memory cards which is located inside your CPU unit and located at the left side your motherboard and beside your processor. Clean it with a pencil eraser. Then put it again in your motherboard. If problem is still there. Try to check your power supply may it dropping voltage where the did not full fill the requirements of your computer. Hope this will help.
Jul 18, 2011 | Computers & Internet
When i turn on my pc, the cpu works perfectly while the monitor "syncmaster591s"....when i turn on the monitor the light (green) beside the button of the monitor is blinking
Try a different monitor...if the different one won't come up then the prob is your video card in the computer...if it does work then the monitor is defective...it would probably be cheaper to get a new monitor than to have the syncmaster fixed
Apr 27, 2011 | Computers & Internet
When I turn on power from main outlet, the amber light at front and fan turn on but when I turn off and on several times, occassionally, the green light appears and pc start working. Could you please tell...
90% of the time a pc that boot randomly comes from a faulty motherboard.
But I can say for shure that it comes from a defective components.
Those kind of troubleshooting needs experience but you can always open the case and look for defective capacitors if you see those on your motherboard it means it is defective and needs to be replaced.
Here is a picture so you can compare : Faulty capacitors
The ones that are flat and clean are good and the ones that are bulged and full of stuff are bad.
Oct 25, 2010 | Dell Dimension C521 PC Desktop
I HAVE BEEN TOLD THE MOTHERBOARD HAS COME UNSODDERED FROM "SOMETHING". I HAVE TO HOLD THE POWER JACK AT A CERTAIN ANGLE TO BE ABLE TO START THE LAPTOP UP, THEN IT WILL SHUT DOWN AFTER 10 SECONDS. CAN...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 15, 2010 | Toshiba Satellite A75-S211 Notebook
My hp pavilion entertainment pc has power but nothing showing on the screen , plus when the pc is first turned on the fan comes on for a few seconds then goes off again . I've tried turning it off and...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 12, 2010 | Computers & Internet
Acer travelmate 5620 Have new replacement battery It does not recognise it
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 04, 2010 | Acer Computers & Internet
The Yellow Port That's In The Inside Where You Plug The Charger in has Broken And Is Very loose And I can reattach It. When I Plug The Charger In The Battery Wont Charge The Whole Thing Wont Come on...
Sep 01, 2010 | Acer Aspire 3680 Notebook
My computer is not starting on battery suddenly after a night while battery is full charged
Take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
Aug 30, 2010 | Computers & Internet
HP dv6000 laptop will not power up
the motherboard has a defective power mosfet on the bottom of the MB beside on the power connector.
Jul 27, 2009 | HP Pavilion dv6119us Notebook
Acer Aspire M1641-U1521A  PC Desktop Logo
670 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
