Question about Hotpoint HSS25GFP Side by Side Refrigerator
H0w to raise the wheels/legs of my hotpoint refrigerator
  • 2,237 Answers
Crescent wrench or open end box wrench.
Posted on Nov 13, 2009
How to level Admiral atf2110dr refrigerator
HS,
Most refrigerators have wheels in the back which are non-adjustable, and in the front they will have wheels and adjustable leveling legs. When I am setting up a new unit, I usually put a screwdriver handle under the middle of the front edge of the refrigerator to raise it up a little and run the leveling legs down until they touch the floor. This will give a little backward tilt to your refrigerator but it will also help your doors to close better. Hope this helps!
Jul 10, 2015 | Admiral Refrigerators
H0w do I clean the machine
put it on rinse add cup of bleach
Oct 06, 2014 | Hotpoint Washing Machines
How to level a new fridge
On the bottom front you should have wheels they may be adjustable depending on the model. Otherwise you will see some octogon looking legs that can be adjusted. You may need a wrench to raise it. Right will bring the legs up and left will bring the legs down.
Sep 04, 2014 | Panasonic NR-BY601VSPH
Level a refrigerator
Rinda,
Most refrigerators will have a leveling leg or wheel at each ot the front corners. What I usually do is lift the refrigerator up and set a block under the refrigerator and turn the legs or the screw for the wheels until they are at the point I want them and then remove the block. In your case, if you have leveling legs you will want to screw them into the refrigerator to lower the front. If you have wheels you will need a screwdriver or a nut driver and un-screw the bolt to lower the front. You may need to take the trim under the door off to access the bolts if you have wheels in the front. Hope this helps!
Jun 04, 2013 | Refrigerators
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Need to get refrigerator levelled. How do I do it
Jan 16, 2011 | Refrigerators
How do level the refrigerator it is a french door with a bottom freezer
most these refrigerators have a small adjustable leg in each corner. Just turn it and it should either raise or lower that leg.
Nov 26, 2009 | KitchenAid Refrigerators
The refrigerator door does not close by itself. When we open it, it stays wide open and we have to push it hard. This is very impractical when we have to use both hands to hold a platter for example.
depending on the model, it sounds like the machine is tilted forward just a bit, if you remove the front toe kick you might find the front wheel adjusters,
or the rear wheels as well, again depending on the model
if you can i would raise the front legs until the entire unit was just out of level maybe half a buble twords the back
this is the typical installation position so that gravity will help door closure past 90 degrees
Oct 16, 2009 | Refrigerators
How do i adjust the wheels on my whirlpool refrigerator?
there is usually a jamb nut at the base of the refrig, have one person raise one side of unit so you can see if this is it, if so take a wrench and loosen jamb nut and adjust leg to your desired height, then retighten jamb nut so adjustment holds,some just adjust w/o a jamb nut
Jul 24, 2009 | Whirlpool ED0GTQXMQ Side by Side...
How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
May 02, 2009 | Amana ATB2132ARQ 33" Top Freezer...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
87 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
