Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Replace Drum I replaced the drum on my Xerox Workcentre 555 but I can not receive faxes. It does allow me to send faxes but will not print confirmation or make copies. Help!!!
  • 2 more comments
  • Anonymous Mar 17, 2014
    How do i reset my drum for xerox workcentre 7245
    When task completed, it now Says "Open the door and replace Yellow (Y) toner cartridge with compatible yellow toner" The Serial number on replacement toner is correct when viewed against the supplies list, we cannot print and or copy until justified. Help!
  • Anonymous Mar 30, 2014
    I have the replacement fuser assembly, and I found the original on the machine, but I can't get the original out. The user guide I have (from Xerox) doesn't specify how to do this, and I don't want just to start yanking on things (that could result in burned fingers, broken parts, and voided warranties). So, how do I get the old fuser assembly out and the new one in?
  • Anonymous Mar 31, 2014
    Need confirmation that fax was sent to the correct fax number and that the number of pages were sent after each fax transmission. How do we select that?
  • 239 Answers
For fax problems, use a analog phone, plug it in. Hear the dial tone, make sure it is a good dial tone, with no static or cutting off. <br /> Use another phone and call to that phone, see if the phone answers and listen to it. Make sure there is no phone noise.<br /> Hang up, and dial to an other phone. See if it answers and also listens to the phone receiver end. Make sure the line sounds good and no noise to it.<br /> What we are looking for is this. One needs to validate the correct phone number to the fax machine.<br /> The other is, to validate the phone number one is trying to call is a known good fax line other machine answers and not an operator or a recording.<br /> If the machine does not receive faxes, the machine is not answering to the ring.<br /> The machine configuration needs to be checked to make sure the setting to receive faxes are inline and correct.(Auto answer, manual answer, etc)<br /> If all of these areas are correct it is possible the fax board is not functioning properly, sending works, but receive will not work. This is a indication the fax board needs to be replaced.<br /> Placing a service call is really a good idea due to the complication of service repair involved in doing the repairs.<!-- from fixya rte -->
Posted on Aug 12, 2010
    President:
  • 2,072 Answers
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory Replace Drum - bttn_print.gifMake Printable Email this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Posted on Jan 08, 2008
My fax says replace drum, which we did, but it won't reset/restart. What is wrong? Is there a code we need to enter?
Yes there is a code, it has been so long I worked on these machines, need to find it.
I will come back later if I do find it and post it.
Jan 25, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
How do I turn off red light after installing new drum in Workcentre 555?
When u restart the printer automatically it will turn off.............
Jul 23, 2008 | Xerox Office Equipment & Supplies
DRUM LIFE WARNING WON'T GO AWAY AFTER REPLACING DRUM.
find the box that the drum came in. There should be directions to reset the drum light enclosed. Or go to www.xerox.com , then look under support and drivers. Good luck !
Jan 11, 2011 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Xerox WorkCentre XD125F- need manual
You can get the spec sheet and the user's guide as PDFs here:
http://www.support.xerox.com/go/results.asp?prodID=XD125f&Xlang=en_US&Xcntry=USA&Xtype=docs&prodName=WorkCentre%20XD125f%20Digital%20Copier%20-%20Laser%20Printer
The spec sheet has the toner cartridge and drum cartridge part numbers (listed as Supplies)
Toner Cartridge 6R914;
Drum Cartridge 13R551
When copier has printed about 18,000 pages the J2 drum cartridge light will come on. The unit will print about another 1,000 pages before the unit stops working until the drum cartridge is replaced.
I hope this helps.
Apr 14, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Right side of Print Out is faded. Cleaned, and Cleaned. Doesn't say to change drum/ink. What else can we try?
You can try shaking the toner cartridge to even out the toner but most likely either need a new toner cartridge or the drum is not sitting evenly as it should.
Sep 11, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
    1. Yes
    2. No
Mar 14, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
197 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
