Drum dose not turn belt is ok no smell or dust
Washing Machine fault. drum dose not turn belt is ok no smell or dust around motor water pumps out ok , Indesit WG 1286. can i test motor on its own
thanks Chris.
    Genius:
  • Washing Mach... Master
  • 1,460 Answers
Fit new motor brush kit if well worn cost about £25 ...
Posted on Nov 13, 2009
Indesit wd1030 washing machine drum not working
Your drive belt may be damaged and needs replacing
Nov 06, 2009 | Washing Machines
Does not spin
Firstly and most commonly it could be that your motor brushes have worn out, and the motor is not turning. It is a simple task to check your brushes just remove them from the motor and look at the end of the carbon if it is very black and burnt it will need replacing and your machine will spin again. On the very odd occasion if the carbon has worn very low it can short circuit the motor and blow a segment out of the armature, if this is the case a new motor is required.
Faulty Belt?
2. This ones fairly obvious, The drive belt could be broken or has come off. Best way to test for this is to turn the drum by hand and if it turns very freely with no resistance and no motor noise then the belt is at fault. If the drum is stiff to turn then you probably have a sock stuck between the drum and tub assembly, in this case you will have to call an engineer.
Blocked Filter Faulty Pump?
3. If you still have water in the drum at the end of the wash cycle then you either have a blocked filter or your drain pump has failed. Firstly check your filter (if fitted) if that is not the problem switch your machine onto spin and if the pump is at fault you will hear a faint hum, if this is the case your pump will need replacing. One other reason is if your drain hose goes to a spout under the sink check it to see if it is blocked as this will cause the same problem.
4. This one is VERY common to more modern machines that are run by electronics (most machines of 6 years or less). This problem arises when you try to spin one item on its own ie: bath mat, dressing gown ect, you will find that all the water has gone but it has not spun, this is because all modern machines use electronics to run all programs and they measure the drum speed very accurately to stop it doing an unbalanced spin. If you ever have this problem simply open the door and put a large dry bath sheet in with the load and spin it again, you should find it now spins OK.
Speed Control Module.
5. Some electronic speed control modules suffer from poor manufacture and the soldering around the relays can burn thus creating a bad contact and eventually an open circuit. If you are lucky and good with a soldering iron you can clean up the joint and resolder it to repair the module. Machines known for this fault are: Hoover Performa, Indesit machines, Ariston, and some older Whirlpool machines. Most modules are located at the lower back of the machine
Oct 15, 2009 | Hotpoint Washing Machines
Kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Nov 11, 2008 | Kenmore 22422 Top Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Indesit we 16 will only turn anticlockwise!
00023398.gif small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
transparent1.gif Find a part for your Washing Machine godark_3.gif How Washing Machines work godark_3.gif What is wrong with your Washing Machine? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Washing Machine godark_3.gif Answers to common questions about Washing Machines (FAQ) godark_3.gif Locate your Washing Machine model number godark_3.gif Accessories for Washing Machines godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for your Washing Machine and get free Washing Machine repair advice for all major brands of Washing Machines including Admiral, Amana, Asko, Bosch, Crosley, Electrolux, Estate, Frigidaire, GE, Gibson, Hotpoint, JC Penney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag, Modern Maid, Norge, RCA, Roper, Sanyo, Speed Queen, Tappan, Westinghouse, Whirlpool, White-Westinghouse, and more.
Jun 29, 2008 | GE WSM2700D Top Load Stacked Washer /...
Washing machine
this clicking of the timer tells you there is a fault somewhere, this could be anything, you have to check things i would do them in this order check the heater element, most common fault second the pump but you said that works then check the motor that drives the drum belt look at the motor control board for any signs of burning etc, this could indicate a motor fault you have not given much info, but with a fault like this thats all you can say, i have given you a brief starting point what and where to look, so happy hunting if i can be of further help get back to me
Oct 06, 2007 | Indesit W 123 Front Load Washer
Washing machine
this indicates a fault unfortunenately it doesnt say which one the most likely problem will be brushes in your motor
Jan 01, 2007 | Indesit WA 115 Front Load Washer
Machine does not move back and forward
it proberly the carbon brushes in the moter get someone who knows what their doing to replace them easy job to do.cost £10
Jun 07, 2006 | Indesit W 123 Front Load Washer
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
