Question about Kitchen Appliances - Others
Creda florida plus shower only working on half heat
  • 95 Answers
Bi-metal unit on top of tank is faulty may have 2 fitted
Posted on Nov 18, 2009
Overheat light won't turn off, strange boiling sound.
it may have calcium build up in the valving.. may need to run some chemical thru it..
Jan 25, 2014 | Home
Where can I get a manual for Creda Panel heater 1500W with Timer 68?
Hi! It seems that this company produces mostly shower accesories, this is why i hope this will do the trick. This is a link that allouds you to read and download for free a installation and operating instructions for creda profile and creda panel heaters ( http://www.tlc-direct.co.uk/Technical/DataSheets/Creda/Creda_NPP_Instructions.pdf ).
I hope this will help you! Have a nice day!
*please don't forget to rate my support :)
Sep 02, 2011 | Heating & Cooling
My creda shower 8500dl won't shut off water keeps
Switch off the power at the main switchbox!
Unscrew the shower cover to reveal the main valve/switch assembly (green in my case)
On the green valve you can line up the bit that moves to select power settings and remove it
Undo the two screws holding the outer switch frame and lift it off
Undo the two screws holding the valve body in.
Remove the valve body, underneath you will find an ordinary tap washer - probably split
Replace the washer - I didnt have an exact match in my toolbox but drilled the middle out of a large tap washer to match
Reassemble..
Aug 10, 2011 | Home
Why does my creda shower say overheat when i turn it on
This could be caused by reduced flow through the shower. Make sure that the shower head is not blacked with Scale, and that your water pressure is not running lower than usual.
Jul 16, 2010 | Home
Shower will not heat up. Creda Aqua 9.5e - was working fine but now no red neon indicator and cold water only. I have checked power going into unit and is ok.
May have a tripped thermal overload or blown fuse. Some overloads reset automatically but some will have a red button to reset it with. Some have to be replaced.
May 02, 2010 | Water Heaters
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Kitchen Appliances - Others Logo
279 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
