Question about Adobe Acrobat 7.0 for PC
I have acrobat 5.0 and acrobat 7.0 on my computer. Most of the time they fail to read acrobat files with an error message ''An internal error has occurred'' appearing on screen. Any suggestions?
  • 691 Answers
Uninstall all your versions, run "ccleaner" and do the registry scan and fix all, do this 3 times to fix everything
restart the puter and install the latest version
Posted on Nov 19, 2009
When i want to open a file it stops 3 times with error message, each time by pressing "ok" it continues to the next stage after pressing "ok" for the 3rd time it opens the file First Error message says"...
Error While Loading Plugin Html2pdf.api may be caused by windows system files damage.
Call on Adobe support number they will help you troubleshoot some common error messages related to Error While Loading Plugin Html2pdf.api that you may receive.
Adobe Customer Support Number
Jul 12, 2017 | Adobe Acrobat 6.0 Professional for PC
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
I keep getting messages ..could not find acrobat External windows handler; . brand is e machines ..error messages,,
Hi Kate1958. I found this for you. Do one or more of the following solutions:
Solution 1: Remove all versions of Acrobat or Reader, and then reinstall one version.
If multiple versions of Acrobat or Reader are installed on the system, remove all versions and then install only one version. See the documentation included with Windows for information about removing programs.
Note: If you need to have multiple versions of an Acrobat product installed, remove all versions and then reinstall them starting with the earliest, installing the latest version last.
Solution 2: Start Acrobat or Reader, and then open the PDF file in the web browser.
If an error occurs when you try to start Acrobat or Reader, refer to Related Documents below, or search the Adobe Support Knowledgebase:
-- If you use Acrobat, go to www.adobe.com/support/products/acrobat.html .
-- If you use Reader, go to www.adobe.com/support/products/acrreader.html .
Solution 3: Make sure that the External Window Handler file (ewh32.api) is in the Plug-ins folder.
If this file is missing, reinstall Acrobat or Adobe Reader.
The default location of the Plug-ins folder is:
-- For Acrobat: Program FilesAdobeAcrobat [version]Acrobat
-- For Reader: Program FilesAdobeAcrobat [version]Reader
Solution 4: Disable Web Browser Integration.
Disable Web Browser Integration so that PDF files open directly in Acrobat or Reader instead of in the web browser.
To disable Web Browser Integration in Acrobat 6.0.x -7.0.x or Reader 6.0.x -7.0.x:
1. Open Acrobat or Reader.
2. Choose Edit > Preferences > Internet.
3. Deselect Display PDF in Browser.
4. Click OK.
To disable Web Browser Integration in Acrobat 5.x or Acrobat Reader 5.x:
1. Open Acrobat or Acrobat Reader.
2. Choose Edit > Preferences > General.
3. Click Options in the list in the Preferences dialog box.
4. Deselect Display PDF in Browser.
5. Click OK.
To disable Web Browser Integration in Acrobat 4.x or Acrobat Reader 4.x:
2. Choose File > Preferences > General.
3. Deselect Web Browser Integration in the General Preferences dialog box.
4. Click OK.
I hope this helps. Please dont forget to rate and provide positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | Computers & Internet
Acrobat fail to load it's core DLL
I would recommend that you go to adobe website and download adobe reader again. You may want to uninstall the one you are using now but not really a necessary.
Oct 25, 2009 | Computers & Internet
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
Can't download pdf file in yahoo mail even after installing adobe
Hello.
Seems that for some reson pdf files are assigned to your microsoft paint instead of acrobat reader.
Try this....
Find an already existing pdf file somewhere on your computer and right click on it and chose properties,
A box will come up where you now click the button that reads "Change".
A list of programs will appear where you now chose acrobat reader.
That should do it.
Regards..
/Tech5508
Feb 15, 2009 | Yahoo Mail
Cant download pdf files.
- Let me know the full details of your problem?
- Check also the Version of your acrobat reader?
- If you have installed Version 5 in your PC then you open the file Version 8 or 9 then the version 5 cannot open.
Sep 25, 2008 | Dell InspironTM 600m Notebook
Reading files
hi,uou can download the latest version of acrobat reader from this link
http://www.adobe.com/products/acrobat/readstep2.html
if you want the adobe 5 click this link
www.brothersoft.com/downloads/adobe-acrobat-reader-5.html
Dec 17, 2007 | Adobe Acrobat 6.0 Professional for PC
CD can't be read by new Adobe Reader
May be trying to re-install your Adobe acrobat Reader could solve the problem.
The files that could not be located can be replaced and the error is gone!
Nov 16, 2007 | Microsoft Office Xp Professional Full...
Adobe Acrobat 7.0 for PC Logo
78 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
