Question about Motorola Mobility W375 Cellular Phone
Are there modem drivers for motorola w375?
Are there modem drivers for w375
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
Drivers to enable communication with vista
download ur driver from
http://driversoftware.cn/motorola-w375-usb-driver/
Mar 05, 2009 | Motorola Mobility Mobile PhoneTools 3.0...
Dont know how to get a handler for my phone
W375 is not now, or sheduled to be,
included in trhe supported phones for Motorola Phone Tools (MPT). The functions that you can get with MPT, ringtones games applications download, are not available.
However
If the phone is plugged into a Windows 2000,xp,vista USB port, there will be a short prompt on the phone screen asking whether you wish to connect the phone as a storage device.
If the answer is yes(left softbutton) the phone will shutdown as a phone and appear in Windows Explorer as a drive with two folders, images and sounds, for background pictures and ringtones.
There is available on the Motorola web site, a charging driver. installed in winXP or win2000, will charge the phone through the USB port on connection and a modem driver to make the cell phone a 9600 modem
No other functions available
Nov 07, 2008 | Motorola Mobility W375 Cellular Phone
Motorola w377
support for the w370 375 etc is limited
in windows xp or higher, the device can be connected to a usb port and it will ask on the mobile phone screen 'connect as a removeable drive?', to enable copying of images and videos,
there is no support to download new java apps or games.
Motorola Phone tools, does not support 370 or 375 and it is unclear if it ever will be updated to do so.
there is a downloadable charger driver at motorola.com so the pc usb port can be used to recharge the w370 w375,
and one to allow it to be used as a modem,
the installers for those packages are not good
Oct 22, 2008 | Motorola Mobility W375 Cellular Phone
Im Looking for the pc suite for motorola W375 where can I get the free drivers??
motorola do not yet support the w370 w375 with the latest version of motorola Phone tools
There is a 370 usb driver for download that also drives the w375, but it only allows explorer access to the images and sounds folders, not to addresses, or to use the device as a mode or any of the expected functions.
there is not supposed to be any driver required for winxp winVista, macs not supported
Jul 17, 2008 | Motorola Mobility W375 Cellular Phone
Unlocking motorla w375
How can i get W375 Motorola USB driver.Because I have datacable but not the driver.
Feb 29, 2008 | Motorola Mobility W375 Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
121 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
