Question about Cell Phones
We are unable to use motorola celphone. when keypads are pressed it shows ''ptt service not available''. what do we need to do?
Unable to switch push to talk
14. Push to talk Push to talk (PTT) is a two-way radio service available over a GPRS cellular network (network service). You can use PTT to have a conversation with one person or with a group of people (channel) having compatible phones. While you are connected to the PTT service, you can use the other functions of the phone. To check availability, costs, additional features and to subscribe to the service, contact your service provider. Roaming services may be more limited than for normal calls. This feature may not be available, depending on your phone. For more information about signing up for the PTT services and the usage, contact your service provider. To connect to the PTT service, select Menu > Push to talk > Switch PTT on. LOOKS LIKE YOU HAVE TO SUBSCRIBE TO USE IT! hope this helps.
Oct 08, 2012 | Nokia 6300 Cell Phone
Cannot set interference eliminator code on my second t5710
First check to see that your keypad is unlocked. You can lock/unlock the keypad by holding in the PTT button for three seconds. You will see a little lock icon when it is locked.
To set the code for a channel:
1. Press Menu until the CODE number begins to flash.
2. Press the + or - to select the desired code.
3. Press the PTT to save the code.
Note: You can set a different code ofr each channel using this procedure.
Zero (0) equals OFF.
If you continue to have problems, set both radios back to a very basic setting with all special featured turned off and see if you can communicate. Then add the desired features back in one at a time until you have what you'd like on both radios.
Best regards.
Oct 06, 2012 | Motorola T5710 (22 Channels) 2-Way Radio
My walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola...
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
My motorola l6 when i switch on it shows ptt services off and all switches are locked how can i switch on the ptt services on ?
It means the PTT switch button gets stack or damage that's why other keys are not working.
If this PTT switch is useful for you, you need to consult a mobile service shop near you for a switch replacement. BUT
If this is not helpful, you can remove it by yourself. just follow this procedure.
(You need a T6 precision screw driver or any tool that can release the screw and a soldering iron to remove the ptt switch)
1. remove the battery cover and the battery pack.
2. release the 4 screws located at the upper portion at the back.
3. remove the plate cover.
4. there are 2 flex connector at the top which lcd is connected and at the bottom which keypad/simcard is also attached. Also the anthenna and the camera is insert prior on the location.
Release them with care.
5. lift up the entire board module.
6. locate where the PTT switch is attach (right side when facing the front phone) then remove it with care by using a soldering iron until the 4 connector of the ptt switch is remove.
7. now assemble the phone and be guide with the pattern on how it was dismantle.
Now check it if other keys is working now, please reply if there is still a problem
good luck... and thank you for visiting Fixya.
Jul 02, 2011 | Motorola Mobility L6 Cellular Phone
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
How could i program/change the freq of my motorola gp2000 manually
I don't think that you could program/change the freq of your Motorola GP2000 manually since newer Motorola radios today everything is done by computer and programming sotfware. You need to have software for GP2000, radio interface box ( RIB) and programming cable for GP2000 radio and these devices are not cheap. The best way is to contact a local repair shop to have it done for you or find a two-way radio technician, he could do this if he has all the test equipments required.
Radcom907
Oct 21, 2010 | Motorola GP300 Compatible 2 Way Radio...
Keypad is not working at all
Hi!... You will need a technical guy with this type of problem, a keypad IC. Its responsible for sending inputs to your phones processor. If I would service it i will reheat the IC or change it.... Your other optinon would be if your phone is under warranty better avail it... or if not try to see a celphone technician.
Jun 18, 2009 | Nokia N73 Cellular Phone
Unable to switch on ptt in my nokia 3110c
push to talk was earlier introduced by tata tele and hutch it is available in tata kyler mobiles which was import by tata from japan and america,but ptt is still in controversies in india due to technological reforms or u may say our own elected illiterate ministers.........so wait for ptt to be lanched by all telecom companies
Apr 01, 2009 | Nokia 3110 Cellular Phone
Motorola L7 keppad not working
hi,
Im getting error
switch PTT service on from settings.
Mar 20, 2008 | Motorola Mobility SLVR L7 Cellular Phone
PTT SCREEN HAS UNABLE TO ADD CONTACT MESSAGE:
I had this problem and we needed to contact our cellular company to verify settings. After some time looking into the problem they said it was a hardware malfunction and swapped phones for us. I think there must be a solution to this problem that the cell representatives did not know about.
Oct 22, 2007 | Motorola Mobility V365 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
