Question about Freecom Portable II External DVD Drive
No response at all from laptop regarding my toughdrive 160GB
After 1yr of no problems my freecom toughdrive 160GB has disappeared regarding my acer laptop. No response at all. Power light is on and can hear drive spinning but no recognition at all. It is not recognised on other computers either, as in nothing at all - no message no nothing. Would appreciate any help. If nothing else can I get my files back?
Many thanks, Rob.
  • robertlloydu Nov 14, 2009
    Thanks argospete, unfortunately I don't have a set up disk, can't remember if I did have one. tried updating drivers etc, still no signs of it anywhere. any other ideas? All much appreciated.
    Master:
  • 956 Answers
Your files are safe on the HDD, the trick to retrieve.
You should have backup at the end of your sessions
If you have the setup disc, reinsert and run!
Posted on Nov 13, 2009
When turned on the harddrive does not make its normal startup noise and worse; the computer does not see the harddrive anymore! The blue light on the front pannel is lit though. Help...
Hi
Check all cable connections in firmly & correct way round, from motherboard & hard drive. Check in bios, make sure hard drive setting is set to Auto. Place you hand on the hard drive to feel vibration. Hard drive could bd faulty. Western Digital are renound for it.
Jun 26, 2014 | Freecom ToughDrive 400 GB USB 2.0 Hard...
Export saved emails from toughdrive, import to my laptop
A little more information. What email program are you using Outlook express? Outlook?
If you are using outlook express open it. go to File / Import / Messages.
select the type of program the emails are in when you saved them to the external harddrive.
click next select import mail from OE6 or whichever you had from above. and click ok.  then click browse. and find the drive the email was saved on. then click the folder you have the emails saved in. and click ok. ( it may be easier to save the email folder to your desktop of your computer and just browse to your desktop).
click next select your folder you want the emails to go to and finish the emails will be imported
Oct 26, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computer doesn't recognise hardrive
It may seem obvious, but did you try a different USB port? Did you try a different computer? and did you try a different cable/cables?
Oct 03, 2012 | Freecom ToughDrive external hard drive -...
What should i do when my freecom toughdrive does not recognize of any computer
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Feb 19, 2012 | Freecom Computers & Internet
Window 7 and Freecom Touchdrive
May be it does not have a compatible driver for the drive. Launch the Add/Hardware wizard and use it to search for a driver on the internet. If a driver is available windows will download and install it.These driver issues usually happen with new operating systems. Even Vista had these problems when it first came out.
Dec 05, 2009 | Microsoft Computers & Internet
Freecom 160gb harddrive not been reconized with usb
you can look at jaycar, **** or rs if the sell the right usb plug and solder it back in.
Jun 09, 2009 | Freecom (24358) 160 GB Network Hard Drive
Files need updating but we have nothing to update them from
Just a long shot but my corrupted Freecom disk started working problem after I simply plugged it into the USB port of a laptop running VISTA. Worth a try as VISTA has the ability to uncorrupt disk structures.
Jan 29, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom external 160gb back up - laptop not recognising back-up drive. Light is on on the drive, but that's all. Help please.
All things considered, I would use a different usb cable to attach the device to your laptop and try updating chip set drivers. The north bridge controls usb hub as well as video.
EverestHome is a software I use to ID the north and south bridge chip sets, the cpu, board, bios etc.
If the external is not detected on other machines then it could be a problem with the external drive chips or connectors.
Apr 18, 2008 | Computers & Internet
Freecom 160GB Hard drive not recognised
Drives do fail Nick. Is it powering up [power supply problem?] Plug it in and go to Start/Control Panel/Admin tools/computer management/storage/ removable storage and disk management. See if the disc is recognised there. If it is not, and if the disk is spinning Try putting it into the deep freeze overnight. Plugging in next morning and if it fires up get as much off as possible before it goes down again.
May 20, 2007 | Freecom (24358) 160 GB Network Hard Drive
Freecom Portable II External DVD Drive Logo
219 people viewed this question
Top Freecom Computers & Internet Experts
callhow
Level 1 Expert
John Anderson
John Anderson
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
