Question about D-Link Computers & Internet
I installed u torrent and the port says its closed. how do i get the rite port open please
If you can, Login to your router.
Probably on an address like:
http://192.168.1.1 or http://192.168.0.1
Once logged in, Find the applications and gaming tab or port forwarding tab.
You will be able to open up ports through this.
Posted on Nov 13, 2009
Got utorrent and down loaded ipv6 ,download speed very very slow disabled ipv6 and uninstalled utorrent and re installed utorrent and tryed other torrent downloaders all say ipv6 installed ,done the...
With utorrent you have to go into the options menu at the top right, then click preferences....once in there click on 'Connection'. The information window to the right has some changes you need to make....the first one where it says 'Port used for incoming connections'...change that to 64450 (you can use any random number over a certain range I generally choose one between 62000-64999). Now right below that, make sure the check box 'Add Windows Firewall exception' is checked. Now click 'Ok' and close the program then go and try to download your torrent.
(If you are using a 3rd party firewall program you will need to go in and enter an exception for utorrent manually)
Feb 23, 2011 | Computers & Internet
U Torrent port is not open since changing from a modem to a router its a Huawei Echolife HG520b type router.Torrent page is showing a red symbol,not green for faster downloading.The fire wall has U Torrent...
See the link below.
You should find this page on your router configuration where you can configure which port is open for which computer.
Its virtual server for your router. Look for NAT under Basic settings.
http://portforward.com/english/routers/port_forwarding/Huawei/EchoLife-HG520b/BitComet.htm
Jan 11, 2010 | Computers & Internet
How can I block *all* torrents traffic with a Cisco 5540 ASA firewall. It consuming too much bandwidth
Well you can use the torrent software to not allowing more bandwidth, just open the torrent software (utorrent, bittorrent etc....) right click on the downloading file then goto the bandwidth allocation menu and select low bandwidth, just do this with all of the downloading things......
Good Luck!!
Thanks
Jan 07, 2010 | Computers & Internet
How to stop torrents on DNA-A211-I bsnl wifi router ? please help
If you have access to the routers control panel
(the address should be something like 192.168.0.1 or 192.168.1.1
with user names and passwords as default, access, admin and so on. Try all of them in all) There should then be a menu to the left with something about ports- click that and follow the on screen instructions.
Disable these Ports 6881-6999( on TCP if the option is avaliable)
this SHOULD stop all bit torrent access. If you want to stop bit torrent all together close all ports. It can still be run through port 80 (the default web port)
Otherwise disable program access on each specific machine that uses Bit Torrent.
Sep 03, 2009 | Computers & Internet
Printer prints only halfway then it stops
Problems described like this always make me think about virus infections. Many time if you download torrent files, the firewall will become disengaged and the program used to download the torrent will begin to capture the port used by the printer. The printer begins to malfunction as a result.
If you are a torent file sharer, stop the practice of allowing the download program to run unattended. Run the printers installation disc to repair the printer software. scan for port violations and open ports. You might have to stop downloading torrent files.
Good luck, jasahasch
Aug 13, 2009 | HP DeskJet F4280 All In One Printer InkJet
Conflict between Gmail and Gtalk
The standard version of GMail requirres afster internet connection. You can solve this problem by slecting the "Older version" or "Basic HTML" versions of GMail.
To enable this, when your Gmail page loads, you will find a link at the top marked as "Older version" and one at the bottom of the page marked as "basic HTML". You can select either of these and you'll surely find a noticeable difference in the speed at which the Gmail page opens.
Thanks.
Jul 24, 2009 | Google Talk
Utorrent. the port problem had been solved. but the connection is still yellow
please check if the port allocated for u-torrent is port-forwarded properly..also check you have assinged a unique port number for u-torrent program..go to options tab in u-torrent and speed guide options in it and check the assinged port number!..or u can visit www.port-forward.com to port forward for the u-torrent!..thank you !!..
Jun 17, 2008 | Microsoft Windows Vista Ultimate Edition
Help
There's a possibility that torrent is being block by the router where your computer is connected to , if internet is working on this computer and torrent is the only one not working you need to open the port for torrent on your router....
Apr 28, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
