Question about Sony KV-AR25M61 TV
I got a problem in TV. TV starts and shutdown immediately, while from sound its looks like that raster is going up but no picture, no sound. Red light is blinking. This happens only when i power off the tv with remote. Kindly assist
  • 19 more comments
  • sikandar841 Nov 13, 2009
    Hi dear,
    The TV is Sony KV-AR25M61. The lights blinks two times and after 3 seconds of pausge it agains blinks 2 times and so one
    THanks
    I don't have schematic, can you send one so i can diagnose and report you for the out come.
    THanks
  • sikandar841 Nov 15, 2009
    Hi
    I changed Q511 but no difference. Than i checked output voltage at pin 5 of IC503 and there was no voltage, I changed IC503. When i start TV it was working normally. I off it and on it again it works fine. I attempted another time and it goes to in same situation as red light blinking two times. I checked IC503 and again there is no voltage. Looks like some component is damaging IC503. Anyways you can give me better solution. Appreciate your earliest response
    Thanks
    As per datasheet of TDA8172 Pin 4 is ground. Anyways i checked already voltage of Pin 2 and Pin 4 and there is no voltage. While rest i have to check. Do you think i have to replace IC503 again?
    I checked R615 its showing 1.045 Ohms, i don't have this resistance
    While i needs to check Q507 and Q509, kindly advise me location if you can
    THanks
    I checked Q507 and Q509 looks working. Just for your information IC601(STRF6456) is getting extremely hot
    KIndly advise
    So what you suggest next
  • sikandar841 Nov 17, 2009
    I replaced R615 and no difference. Q507 and Q509 both are showing low. While IC503 at pin 2 there is no 13 volts. IC601 pin 3 showing 315 volts
    Kindly advise the next action
  • sikandar841 Nov 19, 2009
    I removed Q503 and TV is now on. Kindly advise what i have to do now?
    THanks
    Q503 is protection transistor that gets error signal from Q604, Q509, Q507 and D526
    All above parts need to check for any leakage that trigger Q503.
    Thanks.
    D526 there is no part at PCB, its looks like not used in design. While i checked Q507, Q509, which is looks working. Q604 i needs to check. Do you think we are close to resolve the problem or it might open some more question?
    Kindly comment
  • sikandar841 Nov 20, 2009
    I kept out Q503, TV is working and check voltage at base arround 10-13 v, while TV was on and there was no cable tv connected. While Q604 is OK
    Kindly guide me now
    Can you guide me how to check Q507 and Q509. How i can check low and high. Do i have to keep my meter on DC range and connect - to GND and + to collector?
  • sikandar841 Nov 21, 2009
    Sorry i can't understand your meaning of rejection of solution. Kindly clarify
    THis i really don't have done. Kindly correct it, might be i done by mistaken. I just asked that to check High and low means i have to keep DC meter on DC volt range and connect - to GND of TV and + to collector
    During a detail check i found JR503 near to Q509 which looks like 0 ohms chip is open. I removed from circuit and its open. Kindly guide me can i make a short with a shielded wire because i don't have 0 ohms chip right now
    Kindly assist
    Sorry i mistaken actually i was testing D507 while JR503 is working fine. D507 is also good. I will check as per your last recommendations, will keep you updated
    Thanks
  • sikandar841 Nov 23, 2009
    Hi
    Q509 and Q507 both showing low at collector. While i checked their base is also low
    Kindly advise
    Thanks
    Please find below voltage i got
    Q503
    E 0
    B 0.7
    C 0
    Q507
    E 0
    B varies from -1 to 11 but very dynamic reading
    C 0
    Q509
    E 0
    B 0
    C 1.52
    Hope it will help you to guide me
    Q509 is marked YR, Is it a general purpose NPN transistor? because i have to look for substitute. further you are suggesting that i have to remove Q503 permanently. Is it will not damage and might create a bigger problem after certain time?
  • sikandar841 Nov 24, 2009
    Looks like i'm at bigger problem. I replaced Q509(marked YR) with 1B. I seen on internet its compatible and removed Q503. Unfortunately screen is on but no tuning and screen is coming with color in center only. Further i have powered the TV with controlled current control. TV was taking more than 3A and my device trip the power
    Kindly assist me
  • sikandar841 Nov 25, 2009
    I can do it much before so you don't think so that its possible to make repair with your guidance. I believe there is short circuit as my multimeter probe touch some two connections. Might be this cause some problem when i was testing voltages at transistors
    I will appreciate if you can guide me because i wants to do it at my own.
  • 10,594 Answers
Hi Sikandar,
Let me know how many times red led blinks as there would be an interval of 3 seconds so count blinks from pause to pause.
Is it Sony AR25M61 model or any other?
Above info will help to diagnose problem.
Thanks.
Posted on Nov 13, 2009
  • 20 more comments
  • Shahid Electronics
    Shahid Electronics Nov 13, 2009
    OK,
    2 times blink shows following problems in TV..
    • +B over-current
    (OCP) or over-voltage (OVP)
    • Vertical deflection stopped
    • Horizontal deflection overdrive
    Please check following parts to fix this problem..
    • H.OUT Q511 is shorted. (A board)
    • Q701, Q702, Q703 is shorted (C6 board)
    • -13V is not supplied. (A board)
    • IC 503 faulty (A board)
    Let me know for further query.
    Thanks.
    Service manual / schematics is technical document that can be purchased from nearest Sony service center or part store nearby.
    Below is an image that shows boards location in TV that will help you yo identify boards and find out above said parts in related boards.
    Thanks.
    Shahid Electronics Nov 15, 2009
    Hi
    Thanks
    Good, TV turned On and worked for little time.
    Check +15 volt on pin-2 and -15 volt at pin-4 of IC503 (vertical out).
    Q507 and Q509 are vertical protection/ vertical pulse detector, check its output that should be low.
    Check R615 (1.0 ohm 2w) as this also can cause problem if it gets devalue.
    Hope above info will help.
    In two times blink TV status, horizontal section is not working so there would be no volts at vertical out IC503 and this IC sounds OK because without power/ volts supply it wont work.
    Check Resistor as said above and I would recommend to replace it with exact 1.0 ohm as mentioned above.
    THanks
    These transistors are located near vertical out IC503
    Thanks
    KIndly advise
    Its normal that IC601 gets hot, if its producing +B (135 volts) then its OK.
    Thanks.
    Replace R615 (1.0 ohm 2w) as this also can cause problem.
    Shahid Electronics Nov 17, 2009
    OK, please remove Q503 from circuit, this transistor is connected with pin-18 of IC301 Y/Jungle
    Turn on TV and check.
    Thanks.
    **CORRECTION**
    Above said transistor is connected with pin-20 of IC301
    Shahid Electronics Nov 19, 2009
    THanks
    Thanks.
    more question?
    Kindly comment
    We already solved problem by removing Q503, just testing and checking why Q503 gets ON
    You are right, D526 would not be installed in circuit board.
    While Q503 is out of circuit, check its base input, it should be low.
    Thanks.
    Shahid Electronics Nov 20, 2009
    Q604 is OK
    Kindly guide me now
    Please check Q507 and Q509 out put that should be low.
    Q507 in PNP transistor and Q509 is NPN
    Q507 base should be high to get its collector low and Q509 base should be low to get its collector low.
    Also resolder surrounding chip resistors and chip capacitors.
    Hope this will solve TV problem.
    Thanks.
    Shahid Electronics Nov 21, 2009
    Thank you for rejection of solution.
    Website system told me that you rejected my solution and seeking to another expert here.
    Good luck.
    Alright, Hi and Low means either +5 or so volts and low means 0 volt.
    Put multimeter in DC range, black wire to ground (GND) and red wire of meter will be used to test volts.
    This is Q509 schematic image that might help you..
    and below is Q507 schematics..
    Thanks.
    Congrats,
    Yes, its jumper and you can use any wire on both ends of that opened zero ohm resistor to make it again zero ohm.
    Thanks.
    Thanks
    Its OK,
    Parts that are involve in Q507 and Q509 are mentioned in schematics images. Both transistors output should be Low ( zero volt)
    Thanks.
    Shahid Electronics Nov 23, 2009
    Hi
    Kindly advise
    Thanks
    Q507 base should be High to get its collector Low because it is PNP transistor.
    Q509 base should be Low to get its collector Low
    because it is NPN transistor.
    Well, if you get both transistors collectors Low then its OK, put back Q503 and check its collector should be High (5 volts or so).
    Thanks.
    Q503
    E 0
    B 0.7
    C 0
    Q507
    E 0
    C 0
    Q509
    E 0
    B 0
    C 1.52
    Q503 should Not have .7 volts on base or it will turn On and TV will start blinking.
    Q507 is fine, Collector is Low, good.
    Replace Q509 as it could be leaky that is why collector gives 1.52 volts. It should be 0 volt.
    You can remove Q503 and let it be, TV will work fine.
    Yeah, all 3 transistors are general purpose. Well if you see the problem, TV has no serious problem, its just protection circuit that is causing problem.
    Horizontal, vertical deflection is working fine, power supply is OK, TV is working good, just protection circuit is creating unnecessary command or activating itself on its own without any reason. I do not think removing Q503 will create problem in future.
    Shahid Electronics Nov 25, 2009
    Looks like TV got messed with some wrong action during repair, take it to nearest Sony service center for fix.
    I been providing you info about first TV problem since November 13, 2009 but now it is not possible to fix this TV remotely/ over internet.
    Now it is qualified TV tech job to fix it. Accidental short circuit can cause many problems in TV that can not be diagnosed over internet. If you still want to repair it, get service manual from nearest Sony service center because without schematics, I would not advise to put meter prob some where in circuit board.
    Good bye.
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
KP-61HS30 has sound but no video
1) the problem you have is lack of raster , the problem in tv has 4 phase 1) raster 2) picture 3) synch 4) sound.
2) test the power supply , check the horizontal output +125vdc ,vertical output from +80vdc, +al other circuit +12vdc, if there are missing fix it, see the diagram attached.
3) TEST the signal from tuner,i-f, detector, AGC
GOD BLESS YOU
Jul 12, 2012 | Televison & Video
Rca modeld52w136d dvd combo sound but no picture
are you using RCA jacks? if so make sure that you put the yellow cable in the video out spot ( out to tv) it will have a yellow ring around the opening just like the red one and the white one. ( red and white are for sound only)
Mar 30, 2012 | RCA Televison & Video
When i turn on tv it blinks 7 times no raster and on sound you can hear the high voltage goes up to the picture tube and then stop
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You have a power regulator fault and it shuts down to reduce the X radiation from the tube.
Check the 135Volt line!
Dec 24, 2010 | Sony Televison & Video
My sony wega blinks the standby light red 6 times, pauses and repeats. Cant get a picture on it at all. Any ideas?
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Sep 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    I have a Sony kv-40xbr800. The standby light flashes 6-7 times and does not turn on. If left off for a couple of day, it may turn on. Is there an easy fix?
    SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
    Jun 05, 2010 | Televison & Video
    MY SONNY PROJECTION TV HAS NO PICTURE AND SENSOR LIGHT BLINKS 6 TIMES, NO SOUND JUST ONLY THE RED LIGHT THAT ALWAYS BLINGKING AND EVEN ITS IN THE OFF POSITION STILL BLINGKIN
    hello o Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
    shaun
    Oct 18, 2009 | Sony Televison & Video
    IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
    check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
    Sep 06, 2009 | Televison & Video
    With sound but no video only raster with vertical lines
    The resistor (r9335) on the blue crt base board is open and burned thats why the 200v is missing. replacing the resistor will solve the problem. cheers!
    Apr 08, 2009 | Sony KP-FX532M91 TV
    Stand by light blinks 6 times, wont power on
    Here you find sony blinking codes
    Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
    Sony KV-AR25M61 TV Logo
    880 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
