Question about KDS Valiant 6380iPTD-01 Notebook
My water from my central heating is only warm and not hot even tho thermostat turned up to maxi am having to use the immersion heater as back up which is costing a bomb, i have changed the thermostat on the immersion heater but no change. My central heating system is fueled by oil, i have just had a service on the boiler all ok. Radiators ok and working to required heat.
  • 36 Answers
Your zone valve or three port valve will be sticking
Posted on Jan 24, 2010
  • jollygreenpl Jan 24, 2010
    your zone valve or three port valve will be sticking
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Central heating not working but hot water is ok.
If when you turn power off you wait a while it is probably not the central system coming on. You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in. try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 13, 2014 | Water Heaters
Replaced immersion heater water warm not hot, could it be the honeywell L641A1039
have you checked the thermostat on the heater element is turned right up?
Mar 23, 2013 | Heating & Cooling
I need programming info for an Altech model ALTHC001 central heating and hot water programmer
Can you please tell me how to set clock for central heating the clock is an althc001 had power switch off and when it was turn back on the clock is not working when the boiler is calling for heat and the same with the heating can you help
Oct 07, 2011 | Honeywell Programmable Thermostat Heater
My engine takes forever to warm up so that I can turn my heater on. Then, even when the engine has warmed up my heater never blows hot air, just barely warm. I have a new radiator system and plenty of...
is there a water inlet valve on one of the heater hoses? the valve is to regulate how much water goes in the heater core.
another possibility that happened to me is, the pink antifreeze (dex cool) slimmed up my heater core. i blew it out and my heat was back
Jan 17, 2011 | 1999 Jeep Cherokee
Have a back boiler. Central heating working fine. Hot water not.
Depends on type of control system but usually you will have a three-way motorised valve somewhere. This is contolled by the tiimer and the thermostat on your cylinder. Look for a box that has one pipe going in to it and two further pipes coming out. I suspect yours is stuck on heating. Some models had a manual lever to put it to just hot water. End of the fday you need to get someone out to fix this one.
Jun 16, 2010 | Heating & Cooling
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
My immersion heater keeps tripping out and we have no hot water or central heating, blowing the fuse every time. could we need a powerflush ??
You have an electricl shortage in the system since it keeps tripping or blowing a fuse. Would suggest having system evaluated as soon as possible to prevent any further damage or injury. Good Luck on your repairs
Dave
Oct 20, 2009 | Carrier TSTATHCP Programmable Thermostat...
KDS Valiant 6380iPTD-01 Notebook Logo
247 people viewed this question
Top KDS Computers & Internet Experts
daibras
Level 1 Expert
Cleverer2
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
