Question about Canon PIXMA MP130 All-In-One InkJet Printer
Hi my pixma mp130 has fine horisontal lines whe printing
Have gone through all cleaning process but lines keep coming through on everything i print they are fine and about centermetre apart thanks hope you can help
  • astro_star Jan 09, 2008
    i put in a new black ink and printed some photos it worked fine untill the colour started to run out and then there was indented lines on the print but hoping new cartridge will fix that thank so much
  • 32 Answers
This problem is very simple for printers like these. In normal situations problems involving 2 cartridge (Black & Color) prints degrading in quality involve a failure of the print head nozzles or a calibration error.
It is also possible that you have "cleaned" your cartridges out, as cleaning forces ink through the nozzles at high pressure to force out dried particles, then rubs them off into the stopper sponge.
The beauty and only advantage to two cartridge printers is that if you ever have a print head die or lose print quality, you simply replace the cartridge, since the print head is installed into it.
Print heads and their tendency to fail increase by triple if you use cartridge refills or remanufactured cartridge sets. It is true that 2 cart systems have more expensive ink, but that is the price you pay for convenience. The heads on these cartridges are designed to have a set job life, between 250-600 prints, or the estimated maximum prints in lowest quality ink saver modes, and refilling it causes those heads to keep using the same tiny, high pressure bursts of ink, even after the pumps are wearing and deforming, causing leftover ink in the nozzles, leading to a popped pump or clogged heads.
Thinking in the long term, the next time you upgrade to a new printer, look at a 4 cart or more system, with a dedicated print head. Although the printers can cost an extra $50-$100, these can often times pay themselves back the difference after you have changed each cartridge twice, since you arent throwing away 2 thirds of your color cart when only one color runs out.
I just got a hold of the MP530 by Canon, which yea, compared to the 130 is very expensive.. but the cost per page of printing is about 27 cents lower! I can also bring these removable print heads back to life so easily that I taught a 5th grader how in 5 minutes, so its just a thought!
Posted on Jan 08, 2008
When printing all black areas have vertical lines going through ,have cleaned print heads and changed toner - no change in quality.
Clean the encoder strip, the clear plastic band that runs behind the print carriage. A Q-tip damp with alcohol will wipe off any grease or ink. You'll find a grease spot just above the area on your print that has the vertical line.
Jan 15, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP130 printing lines through pictures etc
I'd say it's probably the printer driver. Uninstal and reinstal it or update it. Printer drivers are a comon cause of printing faults.
Aug 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
May 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Improper printing
Clean the cartridge or replace it.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Won't print a document
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 14, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Problem printing black
You will most likely need to clean out the wasted ink from the cartridge area, this will be a time consuming and fiddly process.
You will also need to clean the heads of the printer with isopropyl alcohol.
if you want to go ahead let me know and i'll walk you through the process although you will end up covered in ink and would most likely be best off getting this done professionally
Feb 12, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Cannon mp130 not printing colour
click on print then a box will come up and select advanced options
and fine where it says print grayscale and then select the color.
Oct 21, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
140 people viewed this question
old marine
old marine
