I have a Wharfedale Slimline MP3 player and I'm
I have a Wharfedale Slimline 2GB MP3 player and I'm trying to buy some new in ear headphones but I can only find headphones with a 3.5mm jack plug - and this is too big for my player. Not sure what size jack socket is - but bought some with 3.5mm jack and it's too big!! I want some of the earbud earphones that fit snugly inside your ear - any idea where I can get them
Found out that jack size i need is 25mm - and then after searching internet have bought an adaptor that has a 25mm male jack with a 35mm female adaptor on other end - so I can use headphones I've bought .
Posted on Nov 16, 2009
Lost my yahoo mail
buy a <a href="http://www.mubuy.com/product/black-sport-waterproof-rechargeable-in-ear-headphone-mp3-player-w-fm-radio-4gb.html" title="Black Sport Waterproof Rechargeable In-Ear Headphone MP3 Player W/ FM Radio (4GB)">Black Sport Waterproof Rechargeable In-Ear Headphone MP3 Player W/ FM Radio (4GB)</a> to sliution your question
Apr 09, 2013 | Computers & Internet
I can only get sound out of one ear. Sometimes, if I move the chord around, I can get sound our of both ears. It comes and goes.
I have had this problem several times. It can be due to a number of things
Firstly, try the MP3 player with a different set of headphones, if both ears work, then the headphones are the problem. Check the adaptor and/or cabling for any damage or defects. If the internal cabling is damaged, you will need to go and buy a new pair.
If the problem is the player itself, try checking the headphone port for dust or any other artefacts blocking the way. This can cause he connection to fail and therefore lose sound.
On a side note, if you love listening to music, i would suggest a high quality set of headphones. Sennheiser (my personal favourites) and Shure are both a VERY good brand to go for. You do pay a bit more, but sound quality and build quality are faultless.
Feb 28, 2011 | Audio Players & Recorders
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
I have broke my headphone? now what can i do
depends on where it is broken and whether or not they are ear buds. ove ear headphones or even the on ear, can be easily repaired by soldering the leads back onto the respective speaker. however ear buds tend to be a bit tougher for a novice to solder. if you broke the cable off of the connector, you are better off buying a new pair of headphones modern wires used in the cables for headphones is coated with a colored (or clear, for the grounds) lacquer that is hard to clean off and still get a good connection. good luck, and i hope this helps.
Apr 13, 2010 | Philips GoGear Flash MP3 Player
Mp3
Your MP3 file might not have any content on the right channel. Try another Mp3 file. If the problem occurs on another file check the hardware:
Unplug the headphones from the mp3 player. Try another set of headphones. If the problem occurs with another set of headphones, it is a broken player. If using another set of headphones cures the problem, try your original headphones again. Plug your original headphones back in. If the problem comes back, buy a new set of headphones.
Sep 23, 2008 | SanDisk Sansa c140 MP3 Player
I have problem wit the colours tat are displayed. its blurred and sort of negative.. mixture of purple, pink.... but i can listen to songs, not a problem wit tat...
hi i have a wharfedale slimline mp3 but my headphones dont work i try to buy more the i need areally small end dont know the size can yoy help
Jun 27, 2008 | Audio Players & Recorders
Internal Connection
Just buy new headphones!
Mar 16, 2008 | SanDisk Sansa e260 MP3 Player
116 people viewed this question
 Grubhead
Grubhead
