Question about HP Officejet Pro K8600dn Color Printer InkJet
The prints show horizontal lines offset.
When I print drawings the horizontal lines are offset every 50mm approximately. Is there any setting in my Imac that might be the cause of this problem as, for example, a draft print setting rather than a best quality print setting?
    President:
  • 1,653 Answers
Do you have a copy of a drawing and a photo of the resultant print that you can send to me at kw7157@yahoo.co.uk as there could be several reasons for this. Also what software are you using on the iMac?
Posted on Nov 13, 2009
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Kodak c140 photos shows horizontal lines
I think, it's a CCD Error. That means a complete Line fails.
Mar 30, 2014 | Kodak EasyShare Cameras
Black horizontal stripes
Black horizontal lines ( page is held Portrait ) ,
where print is affected the print image fails to show behind Line effect but shows in between-
the drum surface has been damaged ( likely wear and tear) and can no longer maintain an even layer of electrons due to leakage/short
solution:
replace the toner cartridge which houses the drum.
Mar 16, 2014 | HP LaserJet 2300 Printer
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
My Dymo LabelWriter 400 is printing vertically. How do I change it to print horizontally? Thanks
Hi Kaylene, i`ve experience that before.. Just set the print set-up/ preview into horizontal.. The dialog box of print preview will show you the position of your text before printing Dymo Label! goodluck!!
Feb 07, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
I have Audi A6 Avant Allroad 2.7 biturbo. Original rim is 6" x 16" offset 15. How wide must the rim be when offset is 35 ?
The rims on cars are often given letter codes indicating the degree of offset. If you wheel is 15mm offset then it should always be 15mm. By fitting wider wheels the wheel not only sticks out further but also sticks in by the same amount. For example if you moved to a 8" width rim, this is an approximate increase of 50mm, the offset of the new rim should still be 15mm but the wheel now sticks out a further 25mm and also stick in by 25mm. The offset always remains the same and any increase in rim width should be balanced either side of the offset line. Failure to do this will result in an altered geometry of tire contact point with the ground. This might make the car take on a an aggressive stance but it will ruin the handling at slow speed and be downright dangerous at high speed.
Aug 24, 2010 | Audi AllRoad Cars & Trucks
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
HP Officejet Pro K8600dn Color Printer  InkJet Logo
146 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
