Question about GE Ultrasonic 2.1 Speaker
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
I have this set. The adapter is labeled Ktec AC adapter model KA12A120150015U. Input 120VAC 60 Hz 260 mA. Output 12V AC 1500 mA, Level 3, I.T.E power supply. I'm surprised it's an AC output, but that's what it says.
Posted on Jun 04, 2010
  • 561 Answers
At most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Posted on Nov 13, 2009
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
What kind of plug adapter does my recorder take?
you will need a 6v or six volt power adapter to use a house hold electrical outlet. You can use it in your vehicle if your adapter can convert 12 volt dc to 6volt dc
May 11, 2014 | General Electric 3-5027a Portable Cassette...
Hello, I lost the power adapter when I moved. Do you know which one I need to purchase, and do you sell them or know where I should buy one? Thanks.
Look on the back or the bottom of your device. The power requirement should be molded into the plastic or printed on a label. Find the voltage and whether it is AC or DC. I'M GUESSING ... it may be 19 volts AC, for example. (I don't know where you live so I dong know what the voltage is at your home or office)
Go to any store that sells electronics and/or computers, they will have a power adapter that will run your device. A good place to start may ge the place you purchased your SmartDisk.
I hope you found this helpful. Thanks for your question @ FixYa.com
Feb 04, 2011 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
Dec 24, 2010 | Koss HD 50 Computer Speakers
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
Ac adapter for my GE speaker system
This is an old type of PC speaker system. Can it be powered by batteries. How many batteries needed??
Multiply the number of batteries by 1.5 volts and you
get the voltage rating of your needed adapter. You can also take a look at the back of these GE speakers. Maybe you can find the voltage rating.
You may also consider buying a new set of PC speaker that can be plug direct to your power outlet.
You can buy it at a cost slightly higher than your
needed adapter.
Nov 11, 2009 | Computers & Internet
Lost my power supply
Having some trouble finding any info online about them. Did they have a large power pack that plugged into the wall? If so, there might be some information either right around where they plugged in (im assuming on the sub) or possibly on the product info sticker on the speaker. Make sure if its a round plug in that you look for the tip information (whether if is a positive tip or negative). You might be better off buying a new set, depending on the price of a new adapter, compared to the price of a new set. Let me know if this helps.
May 11, 2009 | GE HO98015 Computer Speakers
Voltage
iv got same wheel and it is 24v
Mar 12, 2008 | Logitech DRIVING FORCE FEEDBACK STEERING...
Konka model 1508U 12 v dc ADAPRTER PORT
Most devices are Negative to Earth, Chassis and Positive to the Center Pin on the "Adapter". So probably any 12 - 14 Volt say 4Amp well regulated, or Switch Mode power Supply probably would power your unit.. If you don't know the exact voltage Start at about 6 Volts and work up until it works correctly.. I often use a switchable power Supply to find the right voltage and then get a fixed supply to suit.
Aug 31, 2007 | Televison & Video
GE Ultrasonic 2.1 Speaker Logo
369 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
