Question about Electric Izip Mountain Trailz Al Men Bike
Does not do anything when throttle turned, lights show but no power.
  • 4 Answers
Check for lose wiring, including the neutral
Posted on Nov 14, 2009
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
What is a throttle positioning sensor
A throttle position sensor (TPS) is a sensor used to monitor the position of the throttle. If it goes bad (and they do sometimes) it will cause your check engine light to show up. I have never had anything bad happen to any of my cars when the TPS goes bad. Just need to get the part and replace it.
Mar 05, 2013 | 2009 Chevrolet Malibu
What does it mean when code p1516 shows up on a06 chevy impala
It means your Throttle Actuator Control Module senses a problem with your Throttle Actuator Position performance. Here is a link to help you out...
P1516 Chevrolet Throttle Actuator Control Module Throttle Actuator...
May 24, 2017 | 2006 Chevrolet Impala
Throttle cut out check engine light on
This is the fly by wire system. Have you changed the bars or anything lately? You can check the codes by holding in the trip button on the speedo while turning on the ignition. The gauges will sweep,then there will be a PPBS? lettering that comes up on the odometer. Push the trip button once,and it will show the code number for the powertrain,which is where your problem is. Get the code,and we'll go from there.
Sep 24, 2012 | 2008 Harley Davidson FLHR Road king
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
What does reduced engine power light mean and have no acceleration. Turned truck off and reduced engine power went out and everything is ok again; however afraid to drive the truck anywhere now. 2004 GMC...
this model has what they call fly by wire.. no accelerator cable. If the computer detects a problem in the thottle system it will not allow the engine to accelerate and will show reduced power and possibly set a check engine light. The dealer usually wants to replace the throttle assembly which is very expensive and usually un nessesary.
I have had a lot of succes with just cleaning the throttle plates real good.
Jul 08, 2010 | 2004 GMC Envoy
Check engine light is on and the car lost power. By checking with a portable meter, it showed "P2111 TAC system stuck open", what does it mean and how to fix the problem?
It means you probably have a bad TPS (throttle position sensor) or TAC, in the throttle body. Costs about $60. Is easy to change. While in there, make sure the throttle body is clean, because heavy coating of oil water, grit, etc. builds up and will inhibit function.
Jan 03, 2010 | 2004 Toyota Camry
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Electric Izip Mountain Trailz Al Men  Bike Logo
195 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
