Question about Hitachi 50VF820 Projection TV
Picture turned black and white
Picture on all chanells turned black and white-tried playing around with colour menu- didn't maje any difference.
  • 94 Answers
Go to menu select Auto or BK.
Posted on Nov 16, 2009
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white.
programs recorded from tuner are now in black and white
Frank, try new cables and inputs if you can, cables or inputs could be faulty.
Apr 01, 2016 | Panasonic Televison & Video
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
Technika tv/dvd the dvd is only in black and white and wont play the discs
you can try using a DVD cleaner disk on your unit, try several times to make cretin it is clean then try your DVD`s again, if the unit was stored in a damp area this may be a problem, DVD players can be finicky due to this, there may also be a manufacturing defect in the unit that made it fail prematurely.
Jan 09, 2012 | Televison & Video
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model - http://download.rca.com/FilesForRCAcom/Manuals/15491880.pdf
Nov 06, 2011 | RCA F32648 32" TV
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Black and white and feedback
hi this problem usually happens if you have got alot of things plugged into the telly like dvd players this causes the interferance and can be solved by disconecting these other items.
Also are you plugging it into the telly via scart lead or are you using the av leads ie the different coloured ones.
If you are using scart fitting have you tried pressing the av button on the telly controll as if you are not on the right av chanell this will cause black and white pictures so give it a try also this is the same with the coloured leads let me know how you get on.
Make sure their is nothing in the conector at the ps3 end like a biit of paper or fluff as this can cause all sorts of problems and dont use your ps3 on carpet as it will cause unit to get to hot and will cause parts to overheat and will need replacing check all air vents are free from dust and make sure its on hard surface if the unit has overheated it will cost a fortune to repair
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Hitachi 50VF820 Projection TV Logo
126 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
