Question about Electrolux Washing Machines
I have a electrolux EWD124I washer/dryer and the timer knob is just going round after I've selected a wash programme until it reaches off position
  • Electrolux Master
  • 19,396 Answers
Hi.
It sounds like a faulty electronic control.
Parts and wiring must be tested before replacing the timer board.
Regards.
Posted on Nov 13, 2009
My ewf10751 electrolux has working only with washing after i turning round it's knob. how to repair?
change timer may be striped knob age of washer your model posted is wrong check again
Apr 28, 2017 | Electrolux Washing Machines
Washer and dryer does not start.
seems either this dryer is wired up wrong or maybe one of the fuses is out does this dryer have one or two breakers check both are on.
Dec 19, 2014 | Washing Machines
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
I have a front loader model 850 (4.5 kg.).I select programme #5, load the machine and initiate wash cycle. Water is introduced for a few minutes but programme does not proceed. Machine remains...
I just love the way you write. I can tell you are not from the U.S. lol. more than likely your timer/controller is faulty . The little motor than turns it inside is broken.
Oct 29, 2010 | Whirlpool Washing Machines
Timer just spins round
yes it is the timer,i had the same thing happened to me on a hoover,i was told that the fault was when you turn the timer to a programme to do this slowly and gently and if you go pass a programme not to turn it back but to go forward again until you get to the right programme..hope this helps.all the best..ps a new timer may cost about £80 to £100.
Nov 19, 2007 | Hoover PE235 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
