Question about Acer Computers & Internet
How to open acer lcd monitor model no AL1706A
  • 732 Answers
Gulabgoud, Most monitors come apart the same way, or almost!!! May I suggest that you visit YOUTUBE to search and view some video clips of VALID (good) "lcd monitor disassembly" and / or "lcd monitor repair" ??? Have you ever heard the expression "a picture (in your case video clip) is worth a thousand words" Good luck guy, your on your own!!! If this helps you out, please rate this response on fixya. But don't come back here CRYING or complaining IF YOU SCREW UP YOUR MONITOR !!! Bye for now.. 12fix louie
Posted on Nov 13, 2009
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Tip
Repair Acer Monitor LCD 17 In. Model # AL1706A Mfg. Nov 2006
If the power lite is on and there is no Display, Turn off the montor and turn it back on and the picture will flash on for a second - Replace the Capacitor # C806 1000mf 25v to 1000mf 35v in the Power Supply - have to take apart the plastic cover, be very careful in taking it apart it, it will break apart the pieces that hold it together.
on Mar 15, 2010 | Televison & Video
I need the acer monitor drivers for windows seven al1706a
As I'm sure you're aware Acer doesn't offer a specific driver for this monitor. However, any driver for your video card that offers a 1280 x 1024 screen resolution should work. What screen resolutions does your current driver offer? If you want to update your video driver download a newer video driver from the firm that made your video chip. You can find out what you've got by launching Device Manager. (click on the start button and type device manager into the search box) If you decide to update your video driver click on Display adapters entry in Device Manager and right click on the video chip entry that will emerge as a subgroup. Select update driver software from the choices displayed when you right click. Then tell it where the driver you've downloaded is located.
Aug 09, 2011 | Acer AL1706AB LCD Monitor
Flat panel al1706a monitor... Have solid green light by switch and see flashes of light momentarily along with part of the windows opening screen while booting up, then goes black. I studied electronics...
OK, it is pretty easy since you already know the electronics.
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1706&kategoria=monitor&kat2=schematics
Please read below and look through my albums.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 17, 2011 | Acer AL1717 17" LCD Monitor
Green light on and no back ground light in it and no pic i turn it off and on and still no good ,but as of now am used and old sceen till i get it fix right now and i bought this computer in jane of...
Service manuals: http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1706&kategoria=monitor&kat2=schematics
Please read my guide and look at pictures of failed monitors and bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 10, 2010 | Acer AL1706AB LCD Monitor
CONFLICTING WITH WINDOWS SEVEN AND ACER AL1706A MONITOR
update drivers for the monitor in you windows 7 device manager
go to start
the right click on computer
then click on properties
click on device manager
find the monitor in yellow question mark
right click and update driver
make sure your connected to the internet first
That should fix it
if not download drivers fro acer site
Hope this helps Cheers MISTERDJ
Apr 13, 2010 | Acer AL1706AB LCD Monitor
Acer al1706a driver
Just try here : http://www.bioticaindia.com/al1706.html .
If that didn't work , then get back to this website http://support.acer.com/drivers_download.aspx
and try the nearest numbers to your monitor series for example AL1702 or AL1703 or AL1711 .
that works in the most times believe me .
good luck
rate if that was useful please !
Jan 30, 2010 | Acer AL1706AB LCD Monitor
Need to open the case on an ACER 24" LCD Monitor
You are advised to take it in to an authorised technician for repair. Never open the case unless you are qualified and certified.
Jan 02, 2009 | Computers & Internet
Acer Monitor AL1706 freezes w/ horizontal lines after burning cd
The issue is you system, download memtest86 and run it from disk if you get any error your ram is bad or it my be the program you are using try uninstalling it and reinstalling it
Dec 09, 2008 | Acer AL1706AB LCD Monitor
Computers & Internet Logo
1,062 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
