Question about RIM BlackBerry Curve 8310 Smartphone
When I try to take more than one measurement the my TLM130 seems to shut off. Can you advise how I can stop this happening. Cheers Martin.
  • 541 Answers
Problem may be with the software.
Download the software and reinstall the software
Using Blackberry desktop manager.
Posted on Nov 14, 2009
How do you operate on gas? the controls on mine does not seem to work. The ignitor does not work but you can lite it manually. As soon as you let go of the knob the flame goes out. Please advise asap.
Sounds like the ignitor prong has burnt down to far to light the gas and when that happens the thermal safety that shuts of the gas if it gets cold won't get hot so gas flow stops when you let go of the knob
Oct 30, 2015 | Heating & Cooling
My treadmill stops after run for awhile ,why is this happening?
1)Lube the deck belt,this is happening because the lack of lube produce enough friction between deck vs deck belt, and result in shut down.
2)lube The rollers bearing very well
3)measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are Not the board is faulty. see the bloc diagram
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
MY PANASONIC SA-HT75 KEEPS ON CLICKING OFF WHEN I SWITH IT ON.WON'T START UP
There Panasonic SA-ht75 dvd Decreasing the opening treading on what's happening back immediately shuts down
Sep 05, 2011 | Panasonic SC-HT75 System
Blackberry curve is playing up .tried removing battery and re-inserting Tried pressing ALT_right shift DEL to no avail.Just get the alarm going then the screen goes black but the alarm continues.Attempted...
Well seems like water damaged. Get to a local tech and sort it out before it changes into a brick. Also you can upgrade it to latest software by downloading Blackberry desktop manager and follow the instruction. Cheers
Mar 09, 2011 | AT&T Blackberry Curve 8300 Smartphone
2000jgc shuts off while driving. replaced crank shaft sensor, tighten battery connects, no check engine light comes on, no codes avalible. at times one codes does come up when check engine comes o2 sensor...
Have you checked the map sensor? I have known a few vehicles that did this. Sometimes it would go 5 miles, other times 30. Martin, they would get the same code, O2 sensor. If so, I would try to replace that and it probably will solve the issue. The car would die a few times a day. If you have anymore questions, let me know Martin. I am here to help you.
Feb 24, 2011 | 2000 Jeep Grand Cherokee
I need some buckles for the straps on my phil and teds e3
I need the same buckle and just found the original manufacturer. The company is Prym and the buckle is an "overall buckle". Seems that black and white 35mm and 25mm width buckles are available. Check your local haberdashery for it!
Cheers
Martin
Apr 28, 2010 | Phil & Teds E3 - Charcoal Black Jogger...
96 Triumph Adventurer fuel tap replacement
You should not rely on the possibility its metric, it may be BSP, check it by buying a selection of nuts and trying them before you order, but why not just order a seal kit comprising the Dowty washer if its the thread that's leaking?
Mar 23, 2009 | 1996 Triumph Adventurer
RIM BlackBerry Curve 8310 Smartphone Logo
44 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
