Question about Cell Phones
Deepayoor , do u solve the ''locked 1-100'' problem... if yes,then tell me how?? I also face the same. thanks.
I forgot my nokia 3230's lock code how to unlock it please tell me
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 01, 2011 | Health & Beauty
2005 camry xle. remote control will unlock drivers door but not the others. it will lock all doors. inside driver door control will unlock diver door only but will lock all doors. . system worked ok...
Hi Wmannschneid,
I have come across this problem earlier as well,
It seems that the remote has been programmed to ONLY unlock the driver door and not the other doors with one push , to solve this problem you need to follow the below instructions :-
Hold down the lock and the unlock key on the remote TOGETHER for at least 10 seconds and then you will have the setting which will reopen all the doors with one push.
Hope this helps ..:)
Jun 28, 2011 | GPS
Ricoh mpc 2500. apparently i took out the pcu unit, and dumped all the developer out thinking this would solve my black lines issue. well if i buy a new one, would that fix it, or would i need a technician...
Hello sir; You did it right,but only missing one place that is transfer belt unit, there have a cleaning unit (at the end of the unit) just replace cleaning blade should take care your problem.
Jul 13, 2009 | Ricoh Office Equipment & Supplies
Bad catalytic converter(s) ???
let the car run for about 15 min look underneath if the cat is bad its should be glownin
Dec 16, 2008 | 2002 Mazda Tribute
GE Profile Electric Self cleaning oven locked still lit
There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch may solve the problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. usually located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should feel a click.after Reassemble and power up.
hope this solves the problem do let let me know i will appreciate a fixyaa rating thanks and Godbless
Nov 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Yes i have a mitsubishi big screen tv model ws65809 made in 2001 the guns need to be ajusted can you tell me how to ajust them
dear,
what kind of problem u r facing so that u thought the guns adjustments
regards,
dont rate it untill satisfied or solved
Aug 23, 2008 | Televison & Video
Phone got dial lock
Can anyone tell me how to open the dialing lock of panasonic integrated telephone system , for which the password is lost.
please waiting reply
Dec 09, 2007 | Panasonic KX-T7636BK Digital Telephone...
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
