Question about OKI B8300 Laser Printer
OKI B8300 Error code H5-01 - OKI B8300 Laser Printer
5 Suggested Answers
  • 77 Answers
SOURCE: B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Posted on Jun 13, 2007
Soulvisitor
  • 1113 Answers
SOURCE: OKI-B8300 MONO PRINTER
H4-01 Heat roller low temp is correct.
You machine has a fuser unit that it uses to bond the toner to the paper, it does this with  a heater lamp heating a set of rollers that the paper passes threw after it has printed.
Your machine monitors this unit to regelate its temp, your machine is sensing via a thermister and thermal fuse the temp of the fuser unit is not hot enough to enable use, this would mean the heater lamp is blown, thermister is faulty or thermal fuse blown 95% chance it's the lamp,
What one normally does is replace fuser assembly with new this is not a user thing it requires a tec, but if your into it, it is the hi voltage hot bit near paper exit.
Posted on Oct 31, 2007
  • 8 Answers
SOURCE: OKI B8300 Call for Service error
you have a bad laser, try turnuing off/on to clear,if not be prepared to have it replaced
Posted on Feb 17, 2008
taran_2005
  • 10515 Answers
SOURCE: I have a H5-01
H5-01 means that the paper sensor in the fusing unit is defective and needs to be replaced. If you open the machine and clean the entire area around the fuser unit sometimes that will clear the error as well.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 01, 2011
OKI printer es5462w displaying error code 928.what does the error code mean?
it means FUSER MOTOR LOCK ERROR call a tech or you could try replacing the fuser motor
May 19, 2015 | OKI Office Equipment & Supplies
How do I print multiple booklets?
It may be specific to your OKI printer driver. Refer to it's manual.
Apr 24, 2015 | OKI Office Equipment & Supplies
How do I fix the "change toner cartridge" error.
Has the cartridge got a chip? Does this chip need replacing?
Feb 11, 2015 | OKI B8300 Laser Printer
Scanner Init error!!
some solution ? i have the same problem :(
Jul 10, 2012 | Oki Electric Industry Oki MC560N...
ERROR H5:01
HI there ERROR H5:01 mean mechanical problem. This error code says call service person for copier.
Jan 25, 2011 | OKI B8300 Laser Printer
Our Oki 8300 printer has an errror code L4-02. What does this mean?
I have an error code L4-02 with Oki B8300. what is the solution?
Oct 28, 2010 | OKI B8300 Laser Printer
http://www.printcopy.info/shop_e/cdrom.php?brand=OKI
Here is a link to service manuals for OKI
Feb 07, 2008 | OKI B8300 Laser Printer
Oct 30, 2007 | OKI B8300 Laser Printer
B8300 toner error
Jun 12, 2007 | OKI B8300 Laser Printer
Problems printing an A4 document in A3
Ensure that the desired paper is set in a paper tray of the printer and select [Auto] in the paper selection of the printer driver. You may need to configure the margins in the sofware you are using. hope this will help you Daniel
Feb 01, 2006 | OKI B8300 Laser Printer
OKI B8300 Laser Printer Logo
545 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
