Question about Selkirk METALBESTOS 183024 ROUND GAS VENT PIPE TYPE B 3"X2' 3RV-24
Does selkirk metalbestos contain asbestos - Selkirk METALBESTOS 183024 ROUND GAS VENT PIPE TYPE B 3"X2' 3RV-24
  • 119 Answers
Absolutely not they chose a poor term to use
Posted on Nov 15, 2009
Is there any asbestos I creda 59055B models
You will need to call the manufacturer. Don't be surprised if it does. Asbestos is still used in many products today. If you are not sure, treat it as if it does contain asbestos. The main concern is not to breath any asbestos particles. This can only happen if the asbestos is disturbed by drilling, scraping, crushing or anything that can make it air borne. So if it is broken, cracked or crumbling, do not use it. Call an asbestos hot line to find out how to dispose of it.
Feb 24, 2016 | Heating & Cooling
Do Dimplex XT C Storage Heaters contain Asbestos?
Probably a little bit late to be answering this now, but no they do not contain asbestos.
You could have received an answer to this within about 5 minutes by calling Glen Dimplex direct or even any electrical wholesaler
Mar 06, 2015 | Dimplex Heating & Cooling
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
How do I release the front rotor on 2009 Ford Focus
  • Before servicing the vehicle, refer to the precautions section.
  • Remove the wheel and tire assembly.
  • Remove the brake hose retaining clip and hose from the support bracket.
  • Remove the 2 brake caliper anchor plate bolts.
  • Support the brake caliper and anchor plate assembly using mechanic's wire.
  • Remove the brake disc.
  • To install:
    1. Clean the hub-to-rotor contact surfaces of any rust.
    2. Install the brake rotor.
      NOTE If a new brake caliper is installed, use a C-clamp and a worn brake pad to push in the brake caliper piston.
    3. Install the 2 brake caliper anchor plate bolts and tighten to 92 ft. lbs. (125 Nm).
    4. Install the brake hose and retaining clip to the support bracket.
    5. Install the wheel and tire assembly.
    6. Apply brakes several times to verify correct brake operation.
    7. Road test the vehicle for proper operation.
    Precautions
    Dust and dirt accumulating on brake parts during normal use may contain asbestos fibers from production or aftermarket brake linings. Breathing excessive concentrations of asbestos fibers can cause serious bodily harm. Exercise care when servicing brake parts. Do not sand or grind brake lining unless equipment used is designed to contain the dust residue. Do not clean brake parts with compressed air or by dry brushing. Cleaning should be done by dampening the brake components with a fine mist of water, then wiping the brake components clean with a dampened cloth. Dispose of cloth and all residue containing asbestos fibers in an impermeable container with the appropriate label. Follow practices prescribed by the Occupational Safety and Health Administration (OSHA) and the Environmental Protection Agency (EPA) for the handling, processing, and disposing of dust or debris that may contain asbestos fibers.
    Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes. Wash hands thoroughly after handling. If brake fluid contacts the eyes, flush the eyes for 15 minutes with cold running water. Get medical attention if irritation persists. If taken internally, drink water and induce vomiting. Get medical attention immediately. Failure to follow these instructions may result in personal injury.
    If brake fluid is spilled on the paintwork, the affected area must be immediately washed down with cold water.
  • Sep 17, 2011 | Ford Focus Cars & Trucks
    I have a 3 ft stainless double wall chimney that is going thru a ceiling/roof in my garage. there were no instructions on installation. how is this secured? Pls thx Jer
    You can use metal strapping with short self-tapping sheet metal screws also where it penetrates roof a metal collar on inside should be used and a roof collar approved for B-wall vent pipe to keep water from leaking inside on outside on the roof.You can penetrate outside of B-wall vent pipe with short screws to secure the pipe just don't penetrate both pipes.this outside pipe is just a insulator to keep heat from transferring through pipe.
    May 01, 2011 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
    Does my FCXA/FCX24A electric storage heater contain asbestos? The number on is 00401706WW...
    The use of asbestos in insulation and sprayed-on coatings was banned in 1985. I believe your heater is newer than that, so probably not.
    Dec 16, 2009 | Dimplex DS5598 Mid-Size Heater
    Materials list...how to install a two ton gas packaged unit?
    best practice is to consult with a professional that knows about the unit you want to install.
    gas is very dangerous, and can cause great injury or death.
    if you don't know what you are doing, then please hire someone. gas is not something to "tinker" with
    Nov 03, 2009 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
    1999 si honda, asbestos parts
    not any more but be sure you put it the wright way or you will doing it all over again.
    Feb 22, 2009 | 1993 Honda Accord
    Selkirk METALBESTOS 183024 ROUND GAS VENT PIPE TYPE B 3"X2' 3RV-24 Logo
    2,142 people viewed this question
    Top Selkirk Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Selkirk Plumbing Expert? Answer questions, earn points and help others
