Question about Pioneer CDJ-1000 CD Player
My Display Doesn't Light Up
Is There a reset button somewhere in the unit I don't know
  • 1 more comment
  • Cubby121 Jan 08, 2008
    My Display Doesn't Light Ups Is There a reset button somewhere in the unit I don't know
  • Dan Fowler
    Dan Fowler Feb 15, 2008
    Yeap, mine too, I think a leg of the PSU voltage is not getting to the main board. Anybody think I'm correct?
    I need a schematic to figure if sonething is dropped or not.
    THX,
    dan
  • rozez Nov 19, 2008
    wanna know if i can fix this my self or just take it in
N15 Circuit protector on the board underneath the machine, remove bottom plate and there are several, N15 replace with the same value.
Posted on Aug 30, 2008
ONKYO CR-315 cd player locked.
Hello
Just try to reset the CD receiver by holding the clock call button and pressing the STANDBY/ON button.
Nov 30, 2011 | Onkyo CS5VL Super Audio CD Player Black...
A piece of paper tore off while feeding from the rear tray and is lost somewhere inside machine. Yellow light flashes even after shutting off machine for several minutes
Hi! Here is you solution.
1. Open your printer and clean it tightly. 2. And press Reset/Stop button. 3. If it doesn't work properly kindly check the error number which display on you printer LDC... and send back...
Sep 12, 2011 | Canon MP560 All-In-One InkJet Printer
We have a DECT 6 system with a base unit and five satellites. Suddenly the satellite phones don't work, but they are alive (with no dial tone and don't ring) and show a message "out of...
Hello.
From FixYa Support:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
Perform steps for each handset. You may need to plug base unit and unplug for each handset.
Hope this helps.
Jul 27, 2011 | Uniden Cell Phones
HP Officejet Pro L7650 All-in-One Frozen display 83C00020 and Blinking light.
Try resetting it. This will erase all stored speed dials etc for the fax, so be warned before doing this.
Disconnect the power from the printer
Press the # and the 6 together on the keypad
Reconnect the power to the printer
Wait for the display to say "Semi NVM reset" (or something like that) OR the printer will shut off.
When either of those occur, release the buttons on the number pad.
If the unit powered down, turn it back on.
The printer will now go through several minutes of gyrations and dancing about and will finish up with a calibration page.
This reset will fix MANY MANY different issues with HP printers, and if you call for tech support, it's usually one of the first things a tech will have you do - so save yourself that 30 minute hold time and do the reset first!
If you have a lot of phone numbers stored in the unit, and don't want to lose them but still want to reset the printer, you can do a partial NVM reset. It doesn't fix as many issues with the printers, but it's less destructive. It's the "pound three" reset.
You guessed it...do exactly as above, but use 3 instead of 6.
Jul 19, 2011 | HP Officejet Pro L7650 Printer
Hi i got the korg pa50sd when i swith it on it shows me korg pa50sd boot loading files then this goes off, still the light on display is on but blank display with nothing on it ,. i was trying to find any...
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
Jul 11, 2011 | Korg PA50SD Pro 61 Key Keyboard Bundle
When we turn on the console the light goes green for a few seconds then to a blinking red, what do we do? Is there a reset?
There is a reset but I don't think it will solve your problem. A blinking red light usually means there is a hardware malfunction somewhere. Your best bet would be to call Sony at 1800mysony and get it fixed by them. You could try a reset..you can do this by holding the power button down until it restarts itself and then letting go and holding the button down once more. If this doesn't work you are definitely looking at hardware problems. You could try getting some canned air and blowing out all of the vents, it could be that your vents are plugged or your fan is clogged up but if it doesn't start up and run at all it's probably a more severe issue.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
The Danby Millennium Dehumidifer goes not condense any more. Have unpluged the unit, cleaned all of the filters. Is there a way to reset the unit from the controls?
If you unplugged the heater for 12-15 minutes, after turning OFF the Master On/OFF Switch, the electronics should reset themselves. Also, be sure that you don't have the humidity level set to high. Anything above 60% wont' extract any moisture to speak of. If your unit doesn't have an LED display, set the unit on Minimum.
Hope this helps you. Please let me know. Thanks.
May 17, 2011 | Danby DDR401 Dehumidifier
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Audio Players & Recorders
Pioneer CDJ-1000 CD Player Logo
316 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
