Question about Passport 8500 Radar Detector
Detector will come to full highway alert after being on for about 15 minutes and will not shut off. Sometimes cycling the power will correct it but today that didn't work. Help!
I wiped the front lens surface clean with Windex.
Posted on Nov 17, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
Got a whistler xrt-695 from individual. unit powers up goes thru all the frequencie alerts and laser alerts, scans menu to tell what is active. Seems to be perfect. x-band is on, K,Ka, Laser, all of it,...
how long have you had it? Have you had a radar detector before this one? Try a factory reset - hold in the power button and the quiet button, while holding in these buttons plug in the power cord. The unit will beep twice indicating that its reset. Remember the unit is not a "Cop" detector its a radar detector so not all police cars have radar in them and if they do they may not have it turned on.
Mar 31, 2011 | XTR695 Radar Detector
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
Just bought a 1675 from an individual, never used, still in box. In highway mode it keeps giving a random alert on ka. Doesn't seem to be related to any time or location.
Have you tried the unit in a different vehicle to see if the alerting still happens? Are you using two detectors power up at the same time in the same vehicle? If so, this will cause the units to false.
Oct 25, 2010 | DE-1675 Radar Detector
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
BRK smoke/co2 detector - won't stop beeping
sometimes the alarms are ganged to other apartments .. that's so if there is a fire in one apartment then others are alerted as well .. so the low battery warning could be from a neighbor ... also there may be a common ceiling space that will allow you to hear your neighbors detector .. at any rate someone around you has a low battery in their detector .. if they are ganged then that may be an apartment management maintenance item ..
Sep 19, 2009 | Kitchen Appliances - Others
Shuts off after about 15 minutes
If it is gasoline powered, ensure mix is correct if 2 cycle, check exhaust for carbon blockage. Either will cause overheating.
Mar 27, 2009 | Garden
Radar detector
the higher the number the stronger the signal.
Jun 06, 2008 | Vehicle Parts & Accessories
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
Passport 8500 Radar Detector Logo
156 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
